31/10.50/15... no lift...
Ive been working at Discount Tire Co. for about 1 year know so i get to see what fits and doesnt. I tried a 31/10.50/15 on my 88 B2 with no lift. It gave the fender wells a nice full look, i liked it. So then i turned it, and i didnt fit. It hit on the finder. Tomorrow im going to try and fit a 30/9.50/15. Everyone is saying it will fit, so lets see.
What do you guys run? With and without lift?
on
1 Post
Largest tire recommended (by Discount) on stock wheels and no lift is 30x9.50-15. Every chart I've seen says with 4 1/2" lift the largest you can fit under is 31x10.50-15. Anything larger than that requires modification / more body or suspension lift. I'm still in the process of planning out my buildup, I'd -like- to get 33x10.50-15s under mine. We'll see.
I run 235/75R15's on my '87. The tires would rub on the sway bar (if the sway bar was installed) and, occasionally it hits the passenger fender if everything is just right. Technical data I have for Cooper tires suggests that a 30x9.5 is less than 0.5 in taller, so I wouldn't be surprised if it fits acceptably.
BTW, I've put the 31x10.5R15's from my Explorer onto my BII, and they are driveable, but they rub quite a bit if the suspension flexes or when turning sharp.
moofus02
09-17-2014 07:17 PM
racsan
1983 - 2012 Ranger & B-Series
19
04-06-2014 08:58 PM
blinn79
02-16-2002 09:55 PM
