Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-28-2006, 08:30 PM
Steven62387 is starting off with a positive reputation.
carb rebuild
how hard is it to rebuild the single barrel carb on the 300/ 4.9? i have the kit i just dont know where to start, first off getting the dang thing off
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-28-2006, 09:41 PM
N7ghtwolf is starting off with a positive reputation.
Quote:
Two bolts on each side of the carb into the manifold...unscrew those and start from there...
  #3 (permalink)
Old 06-29-2006, 02:00 AM
Bdox's Avatar
Iconoclast
Bdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant future
Be careful not to break the metal heat tube from the manifold to the choke housing. The screws that hold the body together go in from the bottom. Be sure you get the float setting for your exact carb because the specs are different.
__________________
It's only kinky the first time you do it!
Life is short, make fun of it !
Bruce, Nevada Chapter
  #4 (permalink)
Old 06-29-2006, 12:58 PM
Rosie is starting off with a positive reputation.
Make sure to take lots of notes. Making sure you write down everything, espicially where screws go and the order in which you took the items off. Because what came off first will go on last when you put the thing back together. Don't loose patients with yourself either.
I did this job about a year ago. It was kinda overwhelming until I just did one step at a time and it all went back together well. The truck even ran when I was finished!
  #5 (permalink)
Old 06-29-2006, 10:31 PM
jimg is starting off with a positive reputation.
If you have a digital camera, snap away as you go - or even a cam corder. May save your cookies. Also, clean is the secret to the passageways in the carb. Check for play in the butterfly shafts. I have a couple of extra 300 six carbs if you get hopelessly lost - in the $20 range.... but they are the California feedback models.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
