72 360 backfires thru carb
CHECK FOR A BURNED VALVE, i have checked EVERYTHING that they are suggested and spent well over 300 on trying to figure it out. check the head for a burned valve. when you put your foot in it it seems to make a spitting sound through the carb, the valve is not working right so it's not running right, your 360 is basically the same as a 390. check for the heads and you'll more than likely find your problem
ford4her
10-30-2014 09:13 PM
RumRunner742
01-23-2014 01:40 AM
sams123
04-09-2012 10:04 PM
08gasurveyor
41
01-20-2012 09:05 AM
dukes18
02-02-2011 08:58 PM
