E85
http://www.e85fuel.com/index.php
You need to buy a vehicle that is compatible with E85.
They have been manufacturing E85 vehicles since 1998. They are called flex fuel. You can check the link and it will tell how to identify E85 vehicles.
The biggest issue is finding a E85 pump.
I own a 2000 Chrysler E85 mini van and can not buy E85 fuel in Oregon. Both the State and US government have pumps for their motor pool.
Originally Posted by Blueoval_boy_64
what do you have to convert to run E85 in a gas engine?
I am investigating this for my 99 Ranger with the 2.5L four.
Dan
Try this site for E85 stations:
http://www.eere.energy.gov/afdc/infr...e/locator.html
I think you have to use IE to make the locator work tho.
Originally Posted by 99F150
A company in Brazille is making a electronic box that plugs into your fuel injectors and has a switch to run gas of alchohol at any %. A few people here in SD have gotten a hold of this kit and installed it. They say MPG with E85 is very close to straight gas.
Dan
Dan
Torque1st, yes the box is a computer that changes the way the injectors fire. Pulse width and timing I think? Over 50,000 of thease kits are in use in Brazille currently. THe best place for information is on the Brazille web site, they have translated the text to english but the vidieos are not translated.
I question whether this is a better solution than spending the same $ on a custom chip with two programs as I am not sure if the factory computer will adjust timing to go with the increased octane that the E85 provides. This box does nothing to the stock computer, only changes the injectors opperation.
Dan
Dan
Yes, I know what the box does, it expands pulse width to deliver more fuel. The problem comes from not having enuf additional injector time or fuel pump/system volume to enrich the mixture properly. Some vehicles have a some reserve, others don't. Of course you could always replace the fuel pump and lines with larger units and increase injector size. Going to higher fuel pressure may also help if the pump will take it. Right now my son's Contour fuel pump and wiring is struggling with the demands that a standard fuel map is placing on it. A chip would be a better solution since you could also increase timing advance but again the reserve fuel capacity must be there. You would also need multiple programs to use varying proportions of E85 and gas unless you had two separate tanks for fuel.
