E85
ethanol/E85
blue, you could look at a Flextek if you have injectors, you could also look at increasing fuel pressure. If you have a carb, you'll have to change jets. Now, neverminding Torque1st's comment, yes, you may very well get the same or close to it fuel economy. But that depends upon how your engine is setup. The question is if you want to be able to use gasoline again in the future or not. A truck that is intended to be swapped back and forth between gasoline and E85 cannot be optimized to do the best ethanol has to offer. DF, @ his Dad's house
Alcohol is good stuff in a properly designed vehicle that can take advantage of it's properties. We really don't have that in the US yet. Maybe we will get some good supercharger designs that can take advantage of both fuels. Personally I think bio-diesel is a better "alternative fuel" but again that takes a vehicle designed to use it. I follow hybrid vehicle design fairly closely and I am looking forward to some innovative and viable designs in that area.
Originally Posted by Torque1st
You won't get close to the same fuel economy.
I was recently looking at new vehicles on GM's web site (sorry) and they list the expected MPG for gas and E85. The E85 was way WORSE then I thought it could be in MPG. This was for the 5.3
Vortec FlexFuel E85 5.3L V8 (gasoline) 14/18
Vortec FlexFuel E85 5.3L V8 (E85) 10/13
That's a HUGE difference! E85 would have to be dirt cheap for me to think about using it.
Originally Posted by EPNCSU2006
The current flex fuel vehicles are gasoline vehicles able to run E85. If that were reversed so that E85 vehicles were built that could also run gasoline, the fuel mileage story wouldn't be nearly as dismal for E85.
Kinda like "If a frog had wings, he wouldn't bump his butt when he jumped." Might be true, but doesn't change the reality of the current situation.
Yes, there aren't currently produced engines able to take advantage of E85. To do that would require taking away the capability of running gasoline. But it does give the enthusiast some very interesting possibilities. Now, we can build a 12:1 or more motor, for street usage, and actually be able to buy fuel for it! All while being responsible and not hurting the environment. Before E85, this was impossible, unless you like paying $5 per gallon for race gas, which is technically illegal to run on the street anyway due to lead content.
Also, E85 gives the guy that bought the "premium fuel" high compression motor back in the '60's a chance to take it out and run it without fear of pinging!
http://www.leftlanenews.com/2006/05/...opower-engine/
Saab has one.
Saab has one.
#28
#30
You guys completely missed my point. I didn't say that anything you have said is wrong. I was just hoping to put a positive spin on the FUTURE of ethanol. The PRESENT looks just like you've said. Currently, vehicles are optimized for gasoline and E85 performance and efficiency suffers, just like was said before. Sometime down the road, maybe there will be a vehicle optimized for E85 where the gasoline performance and efficiency suffers, opposite of the current trend.
I am working on a vehicle that will be optimized for ethanol with NC State University and Lotus Engineering. It's a long ways from completion, but I will certainly keep everyone informed of how it works out.
