You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Basically, we had questions on whether or not you can add Diesel Kleen to bio fuel and how our 7.3 motors will run on the stuff.
I know a bunch of you are experienced and any knowledge will be most helpful!
Thank ya!
__________________ Lisa Not so Early '99 PSD long bed XLT supercab. 4" Pro Comp suspension lift, 315 BFG AT's on 17" Liquid Metal Gatlins, Casserly Stage 1 injectors, Terminator T-500 HPOP, BTS VB, Cale's tunes, 203* thermostat and billet housing, 6637 w/Pete's cover, CCV, Riffraff oil and fuel crossover, late turbo conversion - international bellowed up pipes, 4" turbo back exhaust, EBPV delete, Harley Davidson headlights, 08 mirrors. 200k club member.
__________________
Early 99 F250 7.3 4x4 Lariat LB SD - DP Tuner, CCV, V10 tranny cooler, 6637, TC lock switch, bunch of LED's, HID headlights, rear/front camera's, Pioneer AVIC-D1 GPS, Oil Guard Bypass, SS HPX, turbo back 4" SS exhaust into Heavy Parts International stacks, Autometer gauges, Zoodad, air horns, new stock chrome wheels...
Nope, no need for BK. BioD is very astringent - it cleans as it flows thru the fuel system. So all the gum and varnish that've collected on the inside tank walls and fuel lines get washed into the filter. If you run bioD, consider changing the fuel filters after the first month. Second, the lubricity is far better than dinoD, so there's no need for Stanadyne lube additive, or any other aftermarket lubricant (Lucas, ATF, etc, etc, etc). Finally, the cetane of most commercially available B20 is around 53, definitely better than the 47/48 that we see here at the pumps in east TX. As you can see, bioD is an outstanding choice of fuel - it cleans, it lubricates, and it burns better and cleaner. Anything you try to add is just wasting $$$.
What about the Cetane and other additives in Diesel Kleen, beyond just the fact that it adds lubricity to the dino diesel?
Same power to be expected with Biodiesel?
Smokin, I put my answer to your questions in your thread, in the 7.3 forum as I thought it would get to more people there.
FABMANDELUX.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
FABMANDELUX.
I've seen that fabman, you rock!
When I finally get around to making biodiesel (I think I found my tank) ...I'll definitely have some questions for you no doubt...
-Lisa (AKA Smokin')
Cetane number for DK or Stanadyne depends on how much you use. BioD ignites faster (higher cetane #), but has less btu's per unit than dinoD. Realistically, it turns out to be a wash - a longer-duration, steady push on the piston. Some folks report better mileage, some report worse; same with the 'seat of the pants' power impression. All state that the engine runs quieter and there's less smoke under acceleration.
TY Marty...I didn't realize there was another thread so similar. Maybe I should look next time ehh?
