1991 Ranger heater core - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-27-2006, 02:11 AM
1988f150pu 1988f150pu is offline
1988f150pu is starting off with a positive reputation.
I need to replace the Heater Core in a 1991 Ford Ranger that I just picked up for my daughter. Any suggestions on the best way to do this??
Old 06-27-2006, 08:04 AM
Rags Rags is offline
Rags is starting off with a positive reputation.
Easy! Remove glove box & there is an access panel with 5 or 6 screws that comes off.
Then go under the hood & disconnect the heater hoses at the fire wall and remove the core.
Make sure you keep some thing on the floor to catch some antifreeze as you remove it.
I think Ranger heater core's are the easiest too replace
Old 06-27-2006, 08:50 AM
Great!!! Thank you for the information...
Old 06-27-2006, 09:21 AM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
Yep, a 91 is before Ford decided to ruin a good thing and redesign the HVAC plenum that forces you to disassemble the entire dash to replace the heater core. Back in the days of my Bronco II it took me perhaps 30 minutes to swap the heater core.
2002 Ranger Heater Core Failure rkmaxwel Ranger & B-Series 17 02-15-2015 03:44 PM
Replacing a heater core in 1987 ranger. superrangerman2002 Ranger & B-Series 5 02-14-2015 04:58 PM
1991 ranger wtroger Ranger & B-Series 2 03-24-2014 12:33 AM
Need seal for heater core. 4x4 Bart 1973 - 1979 F-100 & Larger F-Series Trucks 44 03-07-2014 01:39 PM
2001 Ranger Heater Core dtimval Ranger & B-Series 16 12-07-2013 09:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
