Transfer case fluid for '99 F250? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-26-2006, 11:32 PM
Jon G. Jon G. is offline
Jon G. is starting off with a positive reputation.
Hello,
I have a used '99 F-250 PSD and was wondering what kind of fluid goes in the transfer case. Since I don't have the owners manual I am at a loss. I would think some kind of gear oil but I've also heard some later models use ATF.
Thanks,
Jon
Old 06-27-2006, 01:35 PM
CAT_man_963's Avatar
CAT_man_963 CAT_man_963 is offline
CAT_man_963 is starting off with a positive reputation.
Yep you are right on, with the ATF - that's what it takes
Old 06-27-2006, 01:52 PM
wlihntr's Avatar
wlihntr wlihntr is offline
wlihntr has a good reputation on FTE.wlihntr has a good reputation on FTE.
it takes 2 quarts of mercon/dextron III ATF. spend the extra $$ and use a full syn.
Old 06-27-2006, 02:06 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow FREE Owner Manuals
You can download your Owner's Manual free...with a current edition (see link).
http://www.motorcraftservice.com/vdi...&menuIndex1=59
Must have Acrobat Reader, but might be worth your time.
Agree with the other posts, your transfer case takes 2.0 qts of Mercon ATF fluid.
Good luck...
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
what kind of oil is in the transfer case?? jdhudall 1997 - 2003 F150 2 03-28-2013 06:59 PM
Front/Rear Axle and Transfer case oil change questions? bigblockford_390 1999 - 2003 7.3L Power Stroke Diesel 4 03-11-2012 01:58 PM
What kind of fluid for the T-case? crivaro 6.0L Power Stroke Diesel 6 08-04-2011 11:24 AM
Transfer Case Fluid Type straightsixer 1987 - 1996 F150 & Larger F-Series Trucks 1 04-21-2008 03:37 PM
1999 with dana 50 front diff?? No posi options? Jon G. 1999 to 2016 Super Duty 1 12-19-2006 02:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
