Dirty by design ?
You need to get with John (Board Member) or Carrie Renshaw or Larry Shay (Pres) or even Kenyon Nelson (John's father in law). Larry lives along South Omaha Bridge Road near the Pizza Counter (pull into their lot and look to your right and you should see his truck as it is sometimes not seen from the road as it is behing semi trailers). He drives a lifted 05-06 ex-cab superduty. John has an Amber lifted (11" or so) regular cab with boggers. Kenyon has a lifted red ex-cab long box with some white stuff painted on the front. His is also in 11" or so and Boggers range. I think he build a house out by Underwood. Those would be your best bets. Larry is a little slow but a nice guy (I was a year or two older then him in school). You could also check their website and see if you can catch them at a meeting (although I don't think they update it that often).
Good luck.
Good luck.
I hear that he isn't doing to good with it. Something about burring it in sand/water so deep that it pushes sand when he opens the doors and he has to keep it running so the motor doesn't suck water.
Somebody told me that you bought that 1/2 ton. Is that true? Did you get rid of your superduty or ex?
