blower pulley
You could even run a 2.76 upper, with a 2-4-or if you have the guts, 6lb lower. Like dirty diesel said, CAI, I don't have much experience with the predator, but it seems to be good, with a free-er flowing exhaust will make an awesome combo. Don't forget to have it dyno'd to make sure the a/f ratio is ok. Would suck to have the pred. off just a little.
Originally Posted by gddale
how about just changing the processor or the chip will that change the available boost?
Originally Posted by jb1983
The boost is created mechanicly, the only pratical way to add more boost on a supercharger is with diffrent pulleys, (the faster SC spins, the more boost you will recieve). The chips and programers are needed for remaping the fuel system so that you don't get too lean and fry a piston or more. The upper pulley on the eaton is pressed on and from what ive heard a pita to replace whereas the crank pulley is realitively easier. Just remember it you do change the pulley be sure you have a predator programer or a chip, otherwise your in for a harvard lesson. Still waiting (hopefully buy x-mas i can give myself an excuse) to get and interchangeable 4-6 crank pully and a predator programer(which has a built in datalogger .)
Lost Low End Torque Harley F150
Hello everyone. This is my first forum and I need some help here.I have a 2002 harley davidson f150 that we cut the cats off and put some superflow 40s on. now i"ve lost the low end torque.I have a cold air intake,4 pound underpulley new plenum w/ an accuefab singleblade throttlebody and a new flash tuner. So the question is how do I get the low end torque back in it and what would be considered safe to bump the boost up to.I plan on changing the snout pulley to a stock lightning pulley which I believe w/the 4 pound underpulley would give me a total of 4 pounds.
I bought a SVT front drive from WWW.MagnusonProductws.com along with full lenght dyna flow S. S. headers, K&N,4lbl lower pulley,pred. chip. This Harley Dynoed at 466 HP.
kenny nunez
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
03-30-2013 11:00 AM
nizzl01svt
12-18-2004 06:34 PM
Whaler
12-17-2004 12:55 PM
tlfwatch
06-26-2003 09:58 PM
