Cylinder #2 location ? - PO302 error - Ford Truck Enthusiasts Forums
Old 06-24-2006, 04:55 PM
HHjr HHjr is offline
HHjr is starting off with a positive reputation.
Hello everyone. Firt timer here. This looks like a wonderful place .... Been reviewing this forum for a upcoming PO401 and PO302 repair. I am amazed at how often these two DTC's are in the same forum post.
I am the original owner of a 98 E150 Club Wagon Chateau with about 120K on it. Got PO401 and PO302 errors to tackle with the wonderfull data stored on this forum that I am sucking up. Going to remove the EGR and clean the ports and decide after removal to clean or replace the EGR. For the PO302 I am not sure to replace the Boot only or get a COP and boot for # 2CYL. Would a member please tell me which cylinder is number two.
I am not scared of the project ..... do my own brakes, Contour Timing belt and front wheel bearings and did the Alternator on this van. Just not sure fo #2 after a search on this forum. I appreciate the responses offered.
Harold H.
Old 06-24-2006, 05:58 PM
Ahh! the motor is the 5.4L Forgot to add that.
Harold H.
Old 06-24-2006, 06:14 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Welcome aboard, Harold.
Treat the problems separately.
For the P0401, clean the throttle body ports, then be prepared to replace the DPFE sensor. Don't bother replacing the EGR valve, they seldom go bad.
Cylinder #2 is the second cylinder from the front on the passenger side. Plan on replacing the COP and the plug using plenty of dielectric grease on the new COP's boot. If the plug is very fouled, replace all of the plugs as a follow-on project. Use only the Motorcraft plugs specified at www.motorcraft.com If you have never had the plugs replaced, they're probably well worn.
Steve
Old 06-24-2006, 06:22 PM
Thanks Steve. I did have a $1000 repair a little over a year ago and they did replace plugs and COP's on #3 and #8. IAC valve was replaced too. Transmision serviced as well. I will check plug on #2 though. I will get a Chilton or Haynes manual to help too. The procedures do not scare me but the van egine compartment does. Tight mother in there. Thanks man.
HH
Old 01-01-2008, 03:44 PM
rblgroup rblgroup is offline
rblgroup is starting off with a positive reputation.
Can some one help me with location Cyl2
Old 01-02-2008, 02:18 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
Front of engine.
5 1
6 2
7 3
8 4
PO401 code and misfires on 3 and 7 2oo1 4x4 1997 - 2003 F150 1 05-15-2014 08:05 PM
Help!!! Code Issues PO731 & P1751 among others rylan1 Ranger & B-Series 10 11-30-2013 12:18 PM
My 98 F150 401 codes dilemma finally solved! Passe billyboycurran 1997 - 2003 F150 3 02-05-2011 08:42 PM
2003 F450 6.0 Powerstroke Error Codes P132B P0266 P0401 P0460 P2269 rascal810 1999 to 2016 Super Duty 7 04-22-2010 10:25 AM
Check Engine Codes---Help!! kristilynne612 Explorer, Sport Trac, Mountaineer & Aviator 14 01-14-2010 11:12 AM
Tags
1999, 2006, code, cylinder, dtc, e150, error, f150, ford, loacation, location, mercury, missing, po302, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
