1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Will a 305/70/16 fit on my F250?
Old 06-23-2006, 09:38 AM
LXguy's Avatar
LXguy
LXguy is offline
Hey All:
I have an unlifted 2003 F250 V10. I'm looking at the 305/70/16 Terra grapplers. Will they fit on my truck?
Thanks!
Steve
Old 06-23-2006, 01:03 PM
pmasley's Avatar
pmasley
pmasley is offline
They will but with a little of spring rub (this is for a 4WD). I don't think they will work on a 2WD.
Old 06-23-2006, 01:09 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
Well according to the website, they should fit. They measure in at 32.68". But the issue will "might" have is the rim. They recommend an 8" thru 9.5" rim with that tire. Preferred 9" rim.
I am thinking that the OEM SD rim is 8", but it might only be 7". I cannot remember off hand. Maybe someone will chime in here...and give a positive answer.
But for the height issue...no problem. The width issue...might rub. I had the LT285/75R16 tires on my SD at one time. No rub at all. They were at 32.76" in height. Just not as wide.
biz
_____________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old 06-23-2006, 01:10 PM
captkrunch's Avatar
captkrunch
captkrunch is offline
I don't know if this helps you but I have a 2006 with 305/65/17's with no rub at all
Old 06-23-2006, 01:12 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
Ya, but you have the coil front suspension whereas the older model has the leaf front with less space. The '05+ models can handle a larger tire without any lift. We pre-'05s have to worry about those leaf springs.
biz
Old 06-23-2006, 01:40 PM
captkrunch's Avatar
captkrunch
U r right I didn't even pay attention to what year he had.
Old 06-23-2006, 11:21 PM
Betaracer's Avatar
Betaracer
Betaracer is offline
My 295s rubbed (only when cranked to the right the right inside edge would hit the spring) when used on the stock 7" rims, therefore I assume the 305s will rub even more.
Old 06-24-2006, 12:02 AM
MadMedic20's Avatar
MadMedic20
MadMedic20 is offline
I had 305s on my 2000 F250. They fit good. You get some rubbing on the inner plastic fender at full lock. I took my truck off road to the Pismo dunes and had no other problems even getting alittle air.
Old 06-24-2006, 12:43 AM
BobbyDiesel71's Avatar
BobbyDiesel71
BobbyDiesel71 is offline
[QUOTE=LXguy]Hey All:
Thanks!
YES
I had 305/70R16 Nittos on my 4x4 F-350 with no rubbing issues
my buddy with a older F-250 2wd just put them on and they actually fit his
I just went up to a 315/70R17 BFG AT and they look and fit great!
Old 06-24-2006, 07:37 AM
BFR250SD's Avatar
BFR250SD
BFR250SD is offline
Here's pics of 305's on my '04 before the lift.
Minor rubbing under full lock and a hard bump. Just on the plstic fender liner though.
https://www.ford-trucks.com/user_gal...oid=66392&.jpg
https://www.ford-trucks.com/user_gal...oid=83896&.jpg
https://www.ford-trucks.com/user_gal...oid=66390&.jpg
Old 06-24-2006, 08:57 AM
Bernie Lomax's Avatar
Bernie Lomax
Bernie Lomax is offline
Are the 305/70/16s OK on the OEM 16x7" rims? I need to buy tires soon.
Old 06-24-2006, 09:06 AM
BFR250SD's Avatar
BFR250SD
BFR250SD is offline
They are too wide for the "recommended" rim.
You'll were the centers out pretty fast.
The pics I have there are on an 8" wide wheel.
Old 06-24-2006, 09:45 AM
Bernie Lomax
I'm the answer is here somewhere, but what is the biggest tire I can put on my factory 16x7s?
Old 06-24-2006, 09:57 AM
BFR250SD's Avatar
BFR250SD
BFR250SD is offline
285's are okay.
295's are a little over, but guys run them and haven't had problems.
BUT.....you really need to look at the specific tire manufacturers site to see what "they" recommend for their specific tire.
Old 06-24-2006, 10:07 AM
Bernie Lomax
Thank you very much.
Quick Reply: Will a 305/70/16 fit on my F250?
