ford 460 head identification - Ford Truck Enthusiasts Forums
Old 06-22-2006, 11:05 PM
crm318 crm318 is offline
crm318 is starting off with a positive reputation.
i have recenty aquired a set of 460 (385 series) heads. there are casting number and letters on it but i dont know what they mean. are there any sites or links that i could look these up on?
Old 06-23-2006, 06:25 AM
banjopicker66 banjopicker66 is offline
banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.
Ford Casting numbers do have some meaning. For a 460 head, the numbers should read (most likely) like this:
D3VE-AA2A
D= 1970's
3=1973
V=Lincoln line (the 460 was orignally a Lincoln engine)
E=Engine part
AA2A=Revision codes
This is an engineering code, not a date of manufacture code. You will see D1 blocks and D3 heads in late '70s trucks, because they didn't change the engineering codes.
Try searching on the Internet for "Ford casting numbers" or "Ford date codes" and the like.
The date codes are going to be cast somewhere else, and I am unsure how to decode them. Someone else should be able to help out in that regard.
Old 06-23-2006, 07:57 AM
i did see something that said DIAE on one of the intake runners. it doesnt have the code under the valve cover though.
Old 06-23-2006, 09:01 AM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
Try here for code explainations.
http://www.fairlanet.com/partnumbers/
Old 06-23-2006, 10:23 AM
Homespun91's Avatar
Homespun91 Homespun91 is offline
Homespun91 is starting off with a positive reputation.
The casting # is located (on the head) directly above the third exhaust port from the left, in most cases. Some late heads have the codes in other places.
The most commonly found ones are:
C8VE, C9VE, D0VE- all more or less identical & equal, with smaller 75 cc (give or take)chambers, quench surfaces
D2VE- dramatically enlarged chambers to cut compression, no quench surface, prone to detonation
D3VE- similar to C8VE, etc., in terms of the ports & chamber design, but the chamber is "lowered" or recessed into the head roughly .100, which makes the chamber around 92-97 cc & alters the port angles slightly as a result.
Pistons can be gotten for either the early C8VE/C9VE/D0VE or the D3VE chambers. Either head design can work well, with the earlier heads having a slight edge in fully ported, max effort trim. OTOH, D3VE heads are very easy & cheap to find.
Other heads are the D0OE Cobra Jet & D2OE Police Interceptor heads, but they are not very common. There are also occasionally oddball numbers reported such as D4VE & the like which are the equivalent of the D3VE head. Any head with a first letter of E is a EFI head which is not compatible with carb intakes.
Old 06-23-2006, 03:25 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
Quote:
The casting number you listed as bieng on that set of heads indicate they are not for a 460, that casting number would be for a set of 351C 2v, or 400 heads.
Old 06-23-2006, 04:43 PM
Homespun: I have a question about your comment on E- coded 460 heads. Did I correctly read your message to say that a casting such as E6 is an EFI head?
If so, I must disagree with you. There are E3, E5, E6 and E7 heads, all for carburated intakes. I have E6s on my 460 right now, with an Edelbrock Performer intake. These were all made for 1980s vehicles, before fuel injection was utilized.
A carburated 460 was available for model as late as '87 for some heavy duty trucks. Apparently, their weight class didn't yet require FI to meet some or all of the smog standards. I don't know all the details of the weight divisions and smog requirements therefore, but I have dissected several like this, and have seen those casting numbers on carburated engines.
The location for these casting numbers on these heads changed, too. It is underneath the head, on a beveled plane. To see these casting numbers with the head installed on the engine, you have to use a small mirror to see it.
If I have misunderstood, I sincerely apologize.
Old 06-23-2006, 04:51 PM
banjopicker nice catch, but the E7 heads are the first of the fuelie heads but your right on all the rest of the E# casting bieng for carbed engines. Yes the 87 motor homes could be had with carbs but if you look they still had the E6 or even the D3VE casting numbers on them.
Old 06-23-2006, 05:21 PM
Maybe it was a poorly cast 2 then. I haven't seen an E-2 before, though.
But then, my experience is limited to what I have seen, and I am relatively new to the 385 series; most of my earlier experience was with FEs.
Thanks, MB.
Old 06-24-2006, 05:13 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
The casting date codes are easy to spot and decode.
On the 429/460 they are located in the oil galley and look something like this.
*3L24*
This decodes into November 24th 1973.
Because the 429/460 was first built in 1968 we know the year of the decade can't 1963.
Therefore in this case 3 is the year 1973
3 Year
L is the month
24 is the day.
Month codes are
A - January
B - February
C- March
D -April
E - May
F - June
G - July
H - August
J - September
K - October
L - Novemebr
M- December
Ford Never used I in their codes.
Old 06-26-2006, 01:20 PM
they turned out ot be 351 C heads. thanks for the help guys.
1969 460 heads rvb1975 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 11-14-2016 11:12 AM
'94 F250 460 head removal cscott952 1987 - 1996 F150 & Larger F-Series Trucks 2 09-20-2016 06:48 AM
460 heads Tyler Crann Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 02-16-2016 06:51 AM
head interchange 429-460 gumshoe Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 07-21-2014 08:42 AM
460 Heads mcculloughrp Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 12 04-29-2008 10:20 AM
Tags
460, casting, d3, e3, e7, ford, ford460, fuelie, head, heads, id, misunderstood, numbers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
