Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 06-21-2006, 03:46 PM
seventyseven250's Avatar
seventyseven250 seventyseven250 is offline
Garage is empty, add now
seventyseven250 has a great reputation on FTE.seventyseven250 has a great reputation on FTE.seventyseven250 has a great reputation on FTE.seventyseven250 has a great reputation on FTE.
WVO, Onboard processing
Is it possible to make a setup for precessing your used fryer oil on board your truck? Surely a person could set up some kind of system where the raw oil went into an upper tank, and it gravity fed to a lower tank through a filter? Even if it wasn't gravity fed, a person could set up some kind of electric pump.
Does anyone have a setup like this, or is everyone doing the filtering in thier garage?
Reason I'm asking, is a setup like that would work well for someone who was going on a very long road trip.
Anyone, anyone, Bueler?
__________________
2005 F150 SuperCrew Lariat
  #2 (permalink)
Old 06-21-2006, 05:00 PM
willbd willbd is offline
willbd is starting off with a positive reputation.
The issue with onboard procesing is time. The longer the WVO sits the more water drops out. Driving would make it harder to remove any water.
The only good thing is you have a good source of heat.
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Bryan Will
  #3 (permalink)
Old 06-22-2006, 03:12 PM
I'd guess the sloshing while driving wouldn't help any either. How long would it need to sit to separate out a reasonable amount of water? if you had it heating while you drove, and then just let it separate while you parked for the night, would that be long enough?
__________________
  #4 (permalink)
Old 06-22-2006, 03:22 PM
2 of 3 week with some heat cycles.
__________________
Bryan Will
Tags
board, calgary, diesel, driving, filter, filtration, onboard, processing, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
