1988 F-150 Manual Neutral Safety Switch - Ford Truck Enthusiasts Forums
Old 06-21-2006, 02:09 PM
F150owner2u F150owner2u is offline
F150owner2u is starting off with a positive reputation.
Help, CAN'T LOCATE THE OLD ONE needed to replace the switch this is a manual transmission and the book doesn't give a location. If anyone has replaced their neutral safety switch please post a reply.
Old 06-21-2006, 04:07 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Quote:
It is with the clutch pedal and operated by the clutch pedal, look at the pedal and you will see it.
1971 F250 - Neutral Safety Switch Location 71Camper 1967 - 1972 F-100 & Larger F-Series Trucks 6 06-25-2012 10:39 AM
Neutral safety switch bigcountry150 1973 - 1979 F-100 & Larger F-Series Trucks 10 03-11-2011 01:51 PM
Neutral Safety Switch - reverse light problem Dskeet6 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-14-2010 11:29 PM
'93 F 150 Neutral Safety Switch buddyboy69 1987 - 1996 F150 & Larger F-Series Trucks 1 07-24-2010 10:02 PM
1992 F-150 neutral safety switch bart7078 1987 - 1996 F150 & Larger F-Series Trucks 0 08-16-2007 01:35 AM
Tags
1988, 1997, f150, ford, installation, manual, neutral, safety, sensor, switch, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
