Squeaking from the drive shaft
I can hear a squeak, squeak from my drive shaft area when I start from a stop. At higher speeds, it will continue to squeak, but obviously faster. There are times it will only squeak when I am driving then accelerate or hit dips. I plan on fixing it this Friday, but need to know exactly what I should fix. Thanks.
U-joints.
A couple tips - buy good ones that are greasable. Jeffsbroncograveyard.com sells Dana spicer u-joints. They're cheaper and of far better quality than anything you can find in a local parts store. Then don't forget to grease them.
Then rent a ball joint press from autozone or wherever for free. They double as a u-joint press and it makes the job 100 times easier.
