Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > New Jersey Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
New Jersey Chapter Join Chapter Leader: sddesigns
  #1 (permalink)
Old 06-20-2006, 08:06 PM
GeoDaddy's Avatar
GeoDaddy GeoDaddy is offline
Garage is empty, add now
GeoDaddy is starting off with a positive reputation.
Need a Tune-up, or Fuel Injector, or ? ? ?
My Big Black F250, Full Cab, Longbed... I
Have reached a fuzzy point in our relationship. In the last couple of days, it feels kinda sluggish starting up, idling high, sounds like some straining of some mechanical function... until it falls into the next gear.
Only variable that I can think of is the A/C which I am using for the 1st time on this 1999 truck with 230,000 miles.
It kinda feels like it did last March - just before the Water Pump blew.
The only other feeling that I can recall was a couple of years ago when the fellow I bought it from (and I) were driving across country and two Fuel Injectors had to be replaced... but I was too unfamilar with "trucks" to be able to notice any sound... but my friends did.
Sounds like a visit to the Ford Dealership for another skinning???
Thanx
g
  #2 (permalink)
Old 06-21-2006, 09:55 AM
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
What year? What engine? What code number on the driver's door jam?
The first thing I would do, instead of guessing or taking it to the dealership for a prompt raping, is to borrow a code scanner and pull out the codes out of the EEC. Generally when things go awry, the computer in your truck knows about it, and tries to compensate. It can compensate for a while, then you'll start to feel/see/observe symptoms.
If you don't have access to a code scanner, and have a check engine light (or a volt meter, or a 12V test light), you can wire it up like so at the top of this page, then pull codes doing a Key-on, key-off test.
http://frederic.midimonkey.com/f350-eec.html
  #3 (permalink)
Old 06-21-2006, 07:22 PM
GeoDaddy's Avatar
Hmmm... that's some advice. Let me digest it. It's '99 Ford F250 with the V8 Power Stroke. I'll have to check the bar code on the driver's side door.
No warning lights are on.
I don't have a scanner. Are these available/expensive?
I'll let you know when I get a chance to check out this bar code thingy.
Thanx!
g
  #4 (permalink)
Old 03-03-2007, 01:39 PM
matts156's Avatar
matts156 matts156 is offline
1995 Ford F-350
matts156 is starting off with a positive reputation.
The PowerStrokes have a camshaft position sensor that can really screw with the engine's running quality when they start to go south.
__________________
-1995 F350 Super Crew Cab Dually
Mods: B&M Electronic Shift Improver
-1993 F250 Supercab
7.3IDI N-A E4OD, 3.55 NLS
33x12.5x16.5 tires 270K miles
Mods: B&M Electronic Shift Improver, 4" exhaust
  #5 (permalink)
Old 03-03-2007, 02:14 PM
tjc transport's Avatar
tjc transport tjc transport is offline
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
yup, what matts said. sounds like a cam position sensor. where are you at?? if you ain't to far, i have a scanner and Will read it for ya.
if you join the jersey chapter first.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
Tags
2006, 250, 73, 93, dealership, engine, f350, ford, fuel, injection, injector, powerstroke, scanners, truck, tune, tuneup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
