4.6 v8 rebuild - Ford Truck Enthusiasts Forums
4.6 v8 rebuild
Old 06-19-2006, 10:24 PM
highboy's Avatar
highboy highboy is offline
highboy is starting off with a positive reputation.
4.6 v8 rebuild
has anyone here rebuilt a 4.6??I'm lookin at a 93 (i think) crown vic that that he says has a rod knock, its only got 80 thousand on it and its pretty clean. are these a hard engine to work on?? he said it doesnt smoke, its got good oil pressure and there's no antifreeze in the oil, so it can't be in too bad of shape on the inside what do you guys think?? i have no experience with one of these so please help!!
Old 06-21-2006, 04:08 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
The timing chains and OHC's, getting the cam timing correct. These blocks can only be over bored .020, but I'd doubt that you would even need to bore it anyway. If it is indeed a rod knocking, I would just put a crank kit in it and be done with it. These engines last a very long time usually. If you do rebuild the whole thing, get good valve guide seals, the early 90's engines were bad about them leaking and burning a little oil..
Old 06-30-2006, 01:49 PM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
If it is got good oil pressure and nothing showing in the oil then why does he think it has a rod out of it. These engines where a little prone to piston slap. Do a little diagnostic work. if it is a rod knock then you can disconnect the spark plug wire from each cylinder one at a time and the knock will either go away or be noticeably reduced when you find the cylinder with the problem. I have also seen them knock when they had a piece of carbon bouncing around in a cylinder. An automotive stethoscope will also tell you if the knock is high or low, low being an indication of a rod.
04 F-150 Heritage "Old Style" 4.6L Crabby144 2004 - 2008 F150 5 10-20-2014 11:54 PM
'02 4.6L "Low Oil Pressure" quick35th Explorer, Sport Trac, Mountaineer & Aviator 6 05-09-2013 10:04 AM
Oil change on an oil burner? ravens fan 1997 - 2003 F150 5 12-08-2011 09:42 AM
Wonder how long they will last? osbornk 2004 - 2008 F150 18 03-14-2007 04:56 PM
1998 F-150: Rebuild 4.6L or swap-in a 5.4L? Nightrain Modular V8 (4.6L, 5.4L) 2 02-15-2007 12:09 PM
Tags
2006, 46, 46l, 46v8, ford, knock, modular, motor, rebuild, rebuilt, rod, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
