Rebuilding a 1991 302 V8.. need suggestions on aftermarket parts.
Old 06-19-2006, 12:10 AM
redrush40's Avatar
redrush40
redrush40 is offline
Hello all,
First of all my 302 v8 had some issues over the weekend.
the back driver's side cylinder has NO compression,
the truck is off idle because of this (naturally) and is lacking in power now.
The truck has over 184K miles on it, but it is in great shape.
I want to rebuild the engine since was lacking/not up to par in Horsepower, even before this happened this weekend.
The 5.0L was a beast when I put the first 150K miles on it. WHAT AN ENGINE!
Anyways, stuff breaks down over time, that is the way it works!!!!
I want to try to rebuild the engine up to par for driveablity.
I also would like to build an engine that could run another 200K miles and have power and reliablity AS well as fuel economy!!!!
DARN GAS PRICES!
I am thinking of giving the 302cid engine:
- a set of headers (coated in JETHOT!)
- new aluminum cylinder heads (any suggestions what kind for more HP? and NOT to much in the ways of torque).
- maybe some roller rockers?
- Kieth Black pistons?
- new intake?
- I do have a Jaccobs mileage master ignition, from my V6 258cid Jeep engine I could use on this 302cid engine...
I know the stock 302 EFI engine was about 185 HP stock? (am i correct?)
What type of power gains would I be seeing if I added some or a couple of these upgrades?
Again, I am looking for RELIABLE horsepower, as well as MPG!
I love this place!
TONY Z.
#40
Old 06-19-2006, 12:13 AM
redrush40's Avatar
redrush40
Oh ya, I am thinking of upgrading the brakes as well...
any bolt-on kits for the stock front disk brakes?
Like bigger calipers and rotors?
let us start with the engine first though...any tips would help me alot.
or any stories of doing the same with a similar 87-91 302 EFI engine!
TONY Z.
#40
ps. I have the M5R2 5spd. manual transmission as well.
Old 07-04-2006, 09:42 AM
RanchRodsTX's Avatar
RanchRodsTX
RanchRodsTX is offline
Just a tip $$$ wise. I have found that the Ford Motorsport GT40 reman. engine is a bargain. It comes with a warranty and they only use the best parts. These are done by AER Mfg. and I have seen how they build these, top shelf. Check with your local Ford store or www.discountfordparts.com you might be surprised about how cost effective this engine is when you consider machining, parts and assembly.
Old 07-04-2006, 11:43 AM
redrush40's Avatar
redrush40
Please tell me more about this engine, and where I could find info about it.
Do you have an exact link to this website?
TONY
Old 07-11-2006, 08:38 PM
RanchRodsTX
Sorry, I was sleeping on the response request....
Depending on where you are located they are available through any Ford Motorsport dealer. I got mine from Grand Prairie Ford in Texas. Did you try their website? www.discountfordparts.com
Glaser67
64
01-13-2017 10:39 PM
BigDave67
New Member Introductions
12-21-2016 12:09 AM
1972RedNeck
19
12-07-2016 06:51 PM
ech0sh4y
09-08-2015 06:51 PM
bluestuff
1999 to 2016 Super Duty
63
07-18-2008 10:12 PM
Quick Reply: Rebuilding a 1991 302 V8.. need suggestions on aftermarket parts.
