1971 360 fuel pump
Old 08-29-2001, 07:49 PM
greghoffmann's Avatar
greghoffmann
greghoffmann is offline
1971 360 fuel pump
Smelt some gas today and a good thing I stopped and looked at what's up. The o ring on the fuel pump cannister gave out and there was gas a plenty flowing. The truck is parked now at a motel parking lot until I find an o ring. Question is, "Is there a non-canister fuel pump available for this motor?" It would make life one o ring less easier.
1971 F-350 1 ton dump, ground up fully restored w/ 360 motor
Old 08-29-2001, 08:39 PM
6t6merc's Avatar
6t6merc
6t6merc is offline
1971 360 fuel pump
That's probably all you'll find if you're shopping on a budget. Compare new with old and you might find that the new one is shorter, which means your fuel lines will not fit perfectly.
Eric
Old 08-29-2001, 09:41 PM
welderford390's Avatar
welderford390
welderford390 is offline
1971 360 fuel pump
There is a fuel pump for the FE engine that does not have the canister, just goto your local parts house and ask them and they will point you in the right direction. I replaced the canister type on my truck because all it did was leak.
Old 08-30-2001, 06:31 AM
greghoffmann
1971 360 fuel pump
I will call the NAPA guys today. One less o ring is a beautiful thing. Thanks
Old 08-30-2001, 12:26 PM
Matt67's Avatar
Matt67
Matt67 is offline
1971 360 fuel pump
Randall.
06-13-2017 12:30 PM
kdwellssr
02-04-2016 08:08 AM
green_95
11-25-2015 04:45 PM
camerahunter
13
12-10-2014 01:16 PM
mbrad2002
05-27-2003 04:35 PM
Quick Reply: 1971 360 fuel pump
