The official -TOWING- mpg Poll - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
View Poll Results: What's your towing MPG?
5 or less 3 0.78%
6 18 4.66%
7 53 13.73%
8 113 29.27%
9 90 23.32%
10 73 18.91%
11 15 3.89%
12 15 3.89%
13 and better 6 1.55%
Voters: 386. You may not vote on this poll
Old 06-18-2006, 11:07 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
In keeping with Monsta's MPG polls, I decided to make a towing MPG poll.
This should be for towing mileage results after a few hundred miles.
In your post put the following, please.
1. Year
2. Cab configuration
3. Current mileage on the odometer
4. Auto or stick
5. 2WD or 4WD
6. Rear gears
7. Tire size
8. Cap or no (if a P/U)
9. Any aftermarket accessory that has had an effect on your mileage if it is far off the forum's average.
10. Weight, size and configuration of trailer. Fifth wheel, load-leveler, etc, and how much the trailer weighs approximately.
PLEASE KEEP IT V10 MPG RELATED!
Old 06-18-2006, 01:29 PM
benr0 benr0 is offline
benr0 is starting off with a positive reputation.
High as 13, low as 6.1 - Avg 8
I have @5000 miles towing.
1. 2001
2. CC
3. 59,000
4. Auto
5. 2WD
6. 3.73
7. OE
8. Roll-N-Lock
9. None
10. Jayco 31BHS, 33Ft , Reese Dual Cam Hitch, 8000lbs loaded
Old 06-18-2006, 09:53 PM
AerostarTrailHiker AerostarTrailHiker is offline
AerostarTrailHiker is starting off with a positive reputation.
Mileage hase fluctuated from 6.5 to 9.5 at 60 mph. As I have hit 20K miles, mileage is averaging 8.5 mpg as long as I am not heading into a strong headwind.
1. Year = 2006
2. Cab configuration = crew cab
3. Current mileage on the odometer =20000
4. Auto or stick = auto
5. 2WD or 4WD = 4wd
6. Rear gears = 4:30
7. Tire size = 18" Conti's from factory
8. Cap or no (if a P/U) = tonneau
9. Any aftermarket accessory that has had an effect on your mileage if it is far off the forum's average = None
10. Weight, size and configuration of trailer. Fifth wheel, load-leveler, etc, and how much the trailer weighs approximately. Jayco 29FBS Travel Trailer / approx 8K loaded and Reese Dual Cam Equalizer hitch
This truck tows like a dream!
Old 06-19-2006, 02:25 AM
rob17's Avatar
rob17 rob17 is offline
rob17 is starting off with a positive reputation.
Waiting to hit the magical 150 hours.
1. 2005
2. SC Lariat
3. 5080
4. auto
5. 4WD
6. 4.10
7. OE
8. Jack Rabbit retractable cover
9. none
10. 11000, 29' 5th wheel
Rob
Old 06-19-2006, 07:10 AM
samhagar1 samhagar1 is offline
samhagar1 is starting off with a positive reputation.
Towing with following, I get 7.5 and live in Midwest in a virtually flat area. Keep the speeds 65 or below.
1. 2005
2. Crew
3. 5300
4. Auto
5. 4WD
6. 4.10
7. Stock tires
8. Fiberglass Tonneau
9. No alterations
10. 24 ft boat/trailer weighing approx. 6k
Old 06-19-2006, 07:36 AM
rvpuller's Avatar
rvpuller rvpuller is offline
rvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to behold
I posted 8 but it will run between 8 and 9
1 2000
2 SC
3 53000 miles on the OD
4 Auto
5 2WD
6 4.30 gears
7 215/85/16 tires
8 Banks cat back
9 36' 10" 5ver 15K
Old 06-19-2006, 07:39 AM
BFR250SD's Avatar
BFR250SD BFR250SD is offline
BFR250SD has a good reputation on FTE.BFR250SD has a good reputation on FTE.
1. 2004
2. Super Cab
3. 22K
4. Auto
5. 4WD
6. 4.56
7. 36"
8. P/U
9. K&N filter, Superchips Programmer, Flowmaster Exhaust
10. 4-5K open bed trailer with beaver tail ramps
Old 06-19-2006, 09:03 AM
RY54 RY54 is offline
RY54 is starting off with a positive reputation.
About 8mpg average
1. 2000
2. Crew cab
3. 0-228k always the same
4. auto
5. 4wd
6. 3.73
7. 35"
8. open
9. k&n fipk intake, different exhausts (bolt on cat back, straight pipe with cat, straight pipe with no cat, straight through muffler with no cat) nothing ever made a difference
10. Stacked heavy equipment trailers. 5th wheel mostly but some pintle hitch. Weights from 10k to 18k. Highway running at 62mph in 3rd gear.
Old 06-19-2006, 09:44 AM
tfalk tfalk is offline
tfalk is starting off with a positive reputation.
First real tow this weekend with the 06 this past weekend, NJ to Cape Cod and back.
1. 2006
2. Crew Cab
3. 6500 miles
4. Auto
5. 4WD
6. 4.10
7. 265-70-17 Pirelli's
8. no cap
9. No aftermarket accessories
10. 6500 pounds w/car, 24' enclosed car trailer, bumper pull, Equal-i-zer hitch
Old 06-19-2006, 10:41 AM
SLE's Avatar
SLE SLE is offline
SLE is gaining momentum as a positive member of FTE.SLE is gaining momentum as a positive member of FTE.
1. 2003
2. Crew Cab
3. 32,800 Miles
4. Auto
5. 4WD
6. 3.73LS
7. 285/75/R16
8. No Cap
9. Y Pipe Mod and lots of misc stuff maybe -1/2 MPG worth with everything combined.
10. 10k lbs consisting of a 25' Travel Trailer & a 17Ft Boat all hooked together but I get the same with a 10k lb tractor trailer setup and again the same with just the camper by itself so my conclusion is anything over 4-5k lbs yeilds 8mpg pretty consistantly!
I think speed & terrain should also be included because as long as its safe the roads out here are wide open and have 70-75mph speed limits and thats the way I drive so my MPG always suffers a bit because of this compared to other people.
Old 06-19-2006, 11:00 AM
Big Orn's Avatar
Big Orn Big Orn is offline
Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.
1. Year - 1999
2. Cab configuration - SC
3. Current mileage on the odometer - 112,600
4. Auto or stick - Stick
5. 4WD
6. Rear gears - 4.30
7. Tire size - 255/85 (DRW)
8. Cap or no (if a P/U) - No Cap
9. Aftermarket accessory - Single In/Dual out exhaust
10. 24 Ft Gooseneck, triple axle, approx 4500 LB (Total usual load is around 12,000 pounds loaded with tractor w/front end loader and attachments)
Old 06-19-2006, 02:19 PM
GTFord GTFord is offline
GTFord is starting off with a positive reputation.
1. Year - 2004
3. Current mileage on the odometer - 28,500
4. Auto or stick - Auto
5. 2WD or 4WD - 4WD
6. Rear gears - 3:73
7. Tire size - 285x75x16
8. Cap or no (if a P/U) - no cap
9. SuperChip MicroTuner set at tow performance setting. Does not seem to effect milage.
10. 5300 lb. dry weight, 25 foot toy hauler, bumper pull, weight distribution hitch, loaded weight: ~7500 lbs.
I get 8 MPG average on mixed flat and hilly terrain.
I plan on eventually replacing the gears with 4:30s and a y-pipe.
Old 06-19-2006, 04:51 PM
tgarst tgarst is offline
tgarst is starting off with a positive reputation.
1. 99
2. CC SB
3. 32k miles
4. Auto
5. 2WD
6. 4:30's
7. Stock tires
8. no cap fiver hitch
9. no after market
Fiver weights 9k loaded
Flat land in OD @ 55 to 60MPH get 10 MPG towing
Flat and few hills @ 65 to 70MPH get 8 to 9 MPG
Old 06-20-2006, 10:56 AM
Fredvon4's Avatar
Fredvon4 Fredvon4 is offline
Fredvon4 has a good reputation on FTE.Fredvon4 has a good reputation on FTE.
1. 2005
2. Crew Cab 4 door
3. 25K+ miles on odometer
4. 5R110w TorqShift
5. 4WD
6. 4.30:1 LS
7. 275x75x18 ContiTrak M&S
8. No Cap or bed cover
9. No aftermarket accessory that has had an effect on mileage
10. Receiver hitched, Load leveled 34 ft Travel trailer, weighing 12,687lbs loaded
Truck 7884 Lbs
Harleys in bed 1206 Lbs
Adults and gear 965 Lbs
Trailer 12,687lbs
Combined total weight 22,742 Lbs
Typical trip from Central Texas 750 foot elevation up through Texas flat land panhandle into New Mexico through Ratone Pass, and then into Colorado north to Denver then west toward Vail over Loveland pass and Vail pass at the 11,000+ elevation and back to Central Texas is 2890 miles and 365 gallons of fuel for a 7.9MPG trip average
Old 06-20-2006, 06:55 PM
snsgraham snsgraham is offline
snsgraham is starting off with a positive reputation.
Timely Thread
I just got back a week ago from a trip from Tacoma to Palmsprings and back. I was towing a 14' Wells Cargo Cycle Hauler.
My cousin and I went to pick up his 1955 Porsche Speedster (1500#) and bring it back to Wenatchee. Hauled a big dresser Yamaha Venture (700#) on the way down so the towed weight of 4,200# was nearly the same for both directions.
1. 2004
2. CC
3.20,000
4. Auto
5. 4WD
6. 3.73
7. OE
8. None
9. None
10. Wells Cargo Cycle Hauler, 14' approximately 4,200# loaded.
Truck 7,000 lbs.
Miles traveled on this trip: 2,626
Average moving speed (GPS): 56.5 MPH
Total trip time: 43.5 hours (!!)
Average fuel cost: $3.15 per gallon
MPG: 10.3
We went straight down I-5 (awful road) and then up 395 most of the way to Wenatchee. Had some 5K foot elevations on the way home to climb.
Scott
The Official -HIGHWAY- MPG Poll Monsta Modular V10 (6.8l) 95 12-17-2014 10:51 PM
The Official -COMBINED- MPG Poll Monsta Modular V10 (6.8l) 228 01-30-2014 06:17 PM
2011 FTE "Wild Trucks" Round 3 Entry Greywolf Picture competitions 45 01-22-2013 09:41 AM
2011 FTE "Wild Trucks" round TWO entry thread Greywolf Picture competitions 43 05-10-2011 09:32 PM
2010 FTE Online '61-'79 Classic Online Round-4 Entry Thread.('73-'79 Edition) 76f350spercamprspeal Picture competitions 18 03-27-2010 03:46 PM
Tags
1200, 1999, accessories, aftermarket, desert, f250, fox, hauler, hitch, pipe, pound, reese, sc, toy, v10, wd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
