Check Engine problems....98 Expedition 5.4L
#32
#33
My engine check light blinks 54 times while driving down the highway, twice today. It's been intermittently running poorly , I.E. rough idle, shakes in drive and terrible mileage. I reset the engine light by disconnecting the battery and it ran great again for a day, but now uugh! I see all your post and find them very informative, what should I check for? 1998 f150 4x4 5.4L
#34
Probably a misfire, but the fault codes will point you in the right direction.
#35
#37
#38
Can anyone help? I have a 99 expedition 5.4L V8 the Truck is nice had engine problems last year while working on the truck a friend dropped a bolt down one of the spark plug holes. screwed the engine. This year I replaced the engine, Now the same driveability problems are back. 1. excessive engine vibration. Was told to do a power balance test, But the pcm corrects the problem before RPM DROP. 2. No misfire codes. Codes are for cat below thershold bank 2. And p1000 system readiness ont complete.
Studing to become a tech, Instructor not a lot of help with outside projects.
#39
Cat below threshold could be separate issue, or it might be a by product of the vacuum/exhaust leak.
So where are you studying?
DirtMcGurt88
1999 to 2016 Super Duty
10-12-2016 09:26 AM
thegreatgate
1997-2006 Expedition & Navigator
09-29-2015 09:10 AM
PEPpfts
35
01-29-2012 11:53 PM
