Any problems with BD in 6.0's?
Old 05-25-2006, 07:55 PM
B846B's Avatar
B846B
B846B is offline
I am seriously considering running BD in my 2004 6.0 Excursion, but have a few reservations. I have read in several different websites about International not recommending anything over b5. I assume that several of you run b100 in similar motors and year vehicles. Has anyone had any problems with running BD in their newer 6.0's? Is there anything in the 6.0 that may fail as a result of running b100? Some sites that I have read state that b100 is corrosive and can cause seals, gaskets, plastic parts, etc. to fail. Then of course Ford would void my extended warranty that I paid a hefty price for. I know that the filters would have to be changed more frequently, but besides that are there any other issues I should consider? I live in southern Nevada and will be looking into making the BD at home as I do not know of any place that sells it here yet. Any one is southern Nevada have any problems obtaining used oil?
Thanks for everyones input in advance!
Old 05-28-2006, 12:49 PM
Motown Fire's Avatar
Motown Fire
Motown Fire is offline
I have run B99 for about 5,000 miles is my truck with no problems. Idles more quiet and sounds different at startup. Truck runs really well on it.
Old 05-29-2006, 06:52 PM
B846B's Avatar
B846B
B846B is offline
Any problems with hoses, seals, plugs, going bad? I really want to switch to BD but am still a little leary. I have spent a lot of money on my main mode of transportation, don't want it to go bad as a result of using the fuel.
Old 05-29-2006, 08:10 PM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
Fords stand is B5 only of approved biodiesel. Go to www.biodiesel.org for fuel specs and where to purchase fuel. I have used it in all my farm equipment and on my ford diesels for years. I hate to waste a warranty because of fuel.
Old 05-30-2006, 06:49 AM
bhiggins's Avatar
bhiggins
bhiggins is offline
B846B,
I don't think you'll have problems with the hoses and seals and such. Every thing since about 94 has made the switch to synthetic rubber
what i would concern myself with trying to find out is whether or not the fuel will polymerize (sp?) under the new higher injection pressures the 6.0 runs
i don't know but have heard this is the main concern.
Higgins
Old 06-13-2006, 02:30 AM
kennedyford's Avatar
kennedyford
kennedyford is offline
You wont have any probs, the information on corrosive was the use of waste veggie oil specifically linseed. Bio will super lube those injectors and hopefully keep you from replacing them. I know one guy with 180k and 19 injectors on dino. He is taking my suggestion and putting an oil bypass. If you switch to 100 you will have no probs, more power, less noise, more torque, and longer lasting oil. That is the prob with dino is the emmission req.ments and crystalizing carbon in the injectors and turbos during reburn. Bio is ment to be in the 6.0 and then they wouldnt have as much probs.
Old 06-14-2006, 11:00 PM
dieselboy427's Avatar
dieselboy427
dieselboy427 is offline
DON'T DO IT, It'll take the sealant/laquer off of the inside of the tank, plug the fuel lines and filters.
Old 06-15-2006, 12:00 AM
BLK94F150's Avatar
BLK94F150
BLK94F150 is offline
That's just crap build up from the dino diesel being disolved by the biodiesel. After you change the filter a couple of times, everything will be kosher
Mike
Old 06-15-2006, 12:31 AM
dieselboy427
The tanks I've seen pulled rust after fuel is removed. (Tanks removed to diag fuel filter plugging) This isn't only in ford PSD pickups. It happens in industrial, farm, over-the-road, and all other mfrs using steel tanks.
Old 06-15-2006, 04:28 AM
leskwvo's Avatar
leskwvo
leskwvo is offline
I'm pretty sure the tanks on the 6.0 are plastic. At least the 28 gallon one I have is. It has some metel plates around it to protect it from road hazards.
Old 06-17-2006, 11:15 AM
namrehs300's Avatar
namrehs300
namrehs300 is offline
I've been running B20 on and off for a few months now in my 05 PSD. BioWillie. Only difference I notice is that the idle is a little quieter. But from what I can tell, I seem to get just a little less mpg's - like a half to one mpg.
I like the idea that BD does a better job of lubrication. If I don't run B20, then I run regular with DieselKleen additive. That may account for the slightly better mileage with regular - maybe my cetane is higher with regular and the additive than it is with B20 alone?
I've had one fuel filter change since running BD and didn't really notice that they were any dirtier than before. I change every 15,000 miles.
Old 06-17-2006, 07:36 PM
cookie88's Avatar
cookie88
cookie88 is offline
Every Superduty/Excursion from 99-present has plastic tanks. The exceptions would be the cab & chassis trucks with custom tanks.
6.0superduty
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-12-2016 02:01 PM
mxer0022
Nevada Chapter
10-26-2014 05:06 PM
txoutlaw1
01-07-2013 12:06 AM
countrycar
11-21-2012 07:16 PM
993/4ton
Modular V10 (6.8l)
19
08-18-2007 12:06 PM
Quick Reply: Any problems with BD in 6.0's?
