filters and wvo - Ford Truck Enthusiasts Forums
filters and wvo
Old 06-16-2006, 10:36 PM
14psd's Avatar
14psd 14psd is offline
14psd is starting off with a positive reputation.
filters and wvo
Ok I want to run wvo and not have to change fuel filters every other week. For those of you doin' this (and I'm sure this has been asked before) what is your process. Get wvo, let sit for week or so, filter oil, fill tank, heat oil, here's where I get lost. I don't want the brown grit looking stuff in the bottom of the fuel bowl so what do ya'll do. I have the bag filters to filter down to 1 micron and also a filter to get the water out. Please help.
Old 06-17-2006, 06:42 AM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
Well it sounds like you're doing the right things. I filter through a bag filter into a drum which I have a heating element in. I heat the oil for about an hour twice a day for three days. The heater is on a timer. Then I pump this oil through two Goldenrod filter on it's way to the storage drum.
If you are plugging filters in a few weeks and say less then 4-5K miles you may just have real fatty oil.
What type of on board fuel filter are you using? Is it heated?
A cold filter will plug much faster then a warmed filter. Warmed oil hitting a cold filter will also cool the oil and cause blockage as the fats plug up the filter.
Lastly check you oil is it hydrogenated
Old 07-02-2006, 12:22 AM
14psd's Avatar
I figured out my problem was the HIGH pressure lines from the FPR. They were leaking!!!!!!!! bad. Fixed the prob and now have over 2000 miles on this fuel filter. I also have an extra filter right after the fuel exits the tank which filters the oil again down to 2 microns. I also filter my oil with a bag filter from McMaster-Carr. It filters down to 1 micron. Both seem to be doing the trick now.
Anyone here convert an IDI to run off WVO? mozzles Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 01-19-2013 08:25 AM
WVO Safety? zhilton Bio-diesel, Propane & Alternative Diesel Engine Fuels 14 01-30-2009 07:32 PM
WVO Blends IceboxFX Bio-diesel, Propane & Alternative Diesel Engine Fuels 31 06-29-2008 05:33 PM
Best Catalyst 6.0superduty Bio-diesel, Propane & Alternative Diesel Engine Fuels 2 03-19-2008 11:44 AM
Your Filter Setups edub32 Alternative Fuels, Hybrids & Mileage 17 07-05-2005 07:56 AM
Tags
filters, fuel, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
