Winter storage for my 1971 f-350
I am getting close to putting my truck up for the winter. What are the best things to do so that come spring she will be appreciative to come out of hibernation. I do live in Vermont where it can get cold in the winter if this matters. I will also be able to put her in a barn under cover.Thanks, Greg
1971 F-350 1 ton dump, ground up fully restored w/ 360 motor
1. fill the fuel tank FULL. add fuel stabulizer.
run the engine to get the `new` fuel to the carb.
2. remove batery to a warm place and charge properly.
3. set the FRAME on jackstands with the tires `just` off the ground.
4. build a frame to Cover the truck. then tarp it.
5. take the antifreeze down to - 20
6. Restart it every 90 days if you can. Run it till the coolant is hot then 15 min or more.
7. spray around it with insect killer and slide mouse bait under the frame/ on the ground.
__JOHN__Õ¿ö
FTE Club #7
Member-
http://www.cruisin-north.com/
Santa Rosa, Calif.
72 F-250
ICQ#6030753
http://www.ford-trucks.net/users/jbhf250/
https://www.ford-trucks.com/pictorial/big/1972_f250_2.html
__JOHN__Õ¿ö
FTE Club #7
Member-
Santa Rosa, Calif.
72 F-250
ICQ#6030753
Greg, Are you saying that you can't find a day once every two or three weeks that you can't take your truck out for a short period. Some of the guys are taking some pretty hard lines for the winter, IMHO. Ford trucks are run all winter long in Alaska and Canada.
I will admit to never spending more than a couple days north of North Carolina in the winter, but would think that if you removed the cover and cranked the truck and run it to run temp, every two weeks, you should not have a problem.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
John
jowilker
66F100s Rule
My conscern is keeping her out of the salt. They cannot use enough of it here when the snow flies and she is in too good a shape. I am involved in the snow skiing industry professionally , so come the 1st of October I have to change hats and trade my truck for my van.
