Cleaning upper intake manifold?
I just installing a new oil pan, now I need to reinstall my upper intake. The engine idles ok. The eight intake ports all have dripping oil in them, should I clean it before install? Why is there oil in the intake?
If I need to clean it I guess would I remove the throttle body before using carb. cleaner in the intake? Should I clean the throttle body to before installing to the intake?
Is there anything else that I need to clean before installing the intake?
1993 F-150
100,000 miles
302
1993 F-150
100,000 miles
302
A coating of carbon isn't going to hurt anything. There's just as much on the pistons and head. Don't try to clean the TB or you may ruin it. There is a coating inside the TB that can't be removed (should be a sticker on it) or the engine won't run right.
I'd say clean the intake lightly and put it back on.
annaleigh
05-29-2017 10:30 PM
Bad Bad Leroy Brown
11-22-2015 03:12 PM
pdqtimetrialer
08-27-2012 07:17 AM
2005f-150
16
04-22-2011 08:04 PM
