converting 1968 F100 4x4 to Power Steering
Brian, there is no easy, bolt on power steering for these years of 1/2 ton 4 wheelers. If you are willing to do some cutting and welding however, it is possible. I have a kit from Ibeling repair and conversions, (319) 347-2491, in Applington Iowa, that works VERY well. It uses the steering box from a late 70s 1 ton van. The instructions are clear and complete, but it will take at least all day to do it. DF
I've done alot of these. We use 76-79 Ford F150 /Bronco 4x4 boxes. We cut a triangular piece of plate that fits the 3 bolt pattern of the box. We drill and tap have to slot the frame to drop it in. We probably have spares of these if you need. Advantage@Web77.com J.R.
I can see how the steering shafts need to be modified for length but that shouldn't be too much trouble. There is a company that sells new shafts www.borgeson.com. My question is concerning the drag link and other steering parts. Do these need to be replaced, modified? When I get my new p/s gear is it pretty obvious where to cut or notch? Thanks.
Yes, we had to shorten it. My friend has a welder and he cut a short piece of pipe that fit as snug as possible around the shaft. He cut the shaft and set it in angle iron and welded it. Then he slid the pipe over the junction and welded both ends (now double welded). He did this because I was racing and he didn't want it to break. You have to put a small slot in the frame so the triangular steel can slide into the frame so you can bolt the box to it. I could photograph this and send you a CD or email some PIC's so you could see first hand. How close are you to Tucson, AZ?
J.R.
J.R.
bpuleo, I have done this conversion to my 71 f-100 4x4 and did not do any frame reworking.I have sent a download of how I did it to several members, if you would like to see how I did it send me your e-mail address and I will send it to you. Good Luck, you are gonna like this.
I read your email about the power steering conversion and I have a similar situation. I"m trying to add ps to a 1972 4x4 3/4 ton 390 big block. Would that information apply to my truck also? Any suggestions would be appreciated very much. Thanks Joe
