Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-14-2006, 11:54 PM
dieselboy427 dieselboy427 is offline
dieselboy427 is starting off with a positive reputation.
Talking I Found 7.3 PSD IPR O-Rings separately
I have been working on HD, MD, and, LD diesels for a long while, and came across IPR O-rings for Powerstroke. Caterpillar and Navistar share components: IPR, Injector design, and other small parts. The IPR o-rings are almost impossible to get through ford and navistar but caterpillar sells each in its own little bag.
The part numbers are as follows:
033-6028 O-ring
123-3132 Backup ring
033-6039 O-ring
I've never replaced these on a Cat for leaking, only as a service item when doing high pressure oil line. These are faulty on the PSD more often than the IPR but are not serviceable with ford parts. NOW THEY ARE SERVICEABLE!!!
  #2 (permalink)
Old 06-15-2006, 05:36 PM
believer45 believer45 is offline
believer45 is starting off with a positive reputation.
From when mine failed in 2003:
IPR O-Ring Kit:
(Ford) F6TZ-9C977-AN
(International) 1825806C92
International kit cost me $11.00 or so back then.
Dave / Believer45
__________________
'95 F250 PSD, 5-spd, 4x2, Ext Cab, 3:55 rears, 285/75 x 16 Cooper Discoverer ATR, Putco Master Boss boards, open element AIR FILTER, homebuilt REAR BUMPER, with me in the cab (285#) and full of fuel weighs 6,580 lbs (steer 3420 drive 3160) - 280,000 miles.
  #3 (permalink)
Old 06-15-2006, 11:03 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold
Impeccable timing gents. I've been looking for a way to get an IPR o-ring kit without having to give Ford $40.
Thanks for the info.
__________________
Scott - FTE moderator
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods.
Hers: 98 Navigator, 5.4, AT, 4x4, Old.....but still a Lincoln ;-)
  #4 (permalink)
Old 08-11-2009, 03:51 PM
Cratos Cratos is offline
Cratos is starting off with a positive reputation.
so do you just replace the o-rings or do you have to open it up beside removing the magnet?
  #5 (permalink)
Old 08-11-2009, 08:18 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
1996 Ford F-250
RÖENTGEEP has a good reputation on FTE. RÖENTGEEP has a good reputation on FTE.
Quote:
IPR O-Ring Kit:
Dave / Believer45
Same here
Quote:
Till I know you have to take out the IPR completly.
__________________
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 143K.
DIY intake and exhaust brake. DP 3-3.5" ceramic coated; HPX; GPR switch; Isspro gauges; shim FPR; tranny cooler; CCV mod; 4" stainless Magnaflow; SS 5" tip; no cat; RacerX VB; TW 6p chip; 203*.
«Primum non nosere»
  #6 (permalink)
Old 08-11-2009, 09:20 PM
BlueMule's Avatar
BlueMule BlueMule is offline
BlueMule is gaining momentum as a positive member of FTE. BlueMule is gaining momentum as a positive member of FTE.
You can do either. You can't replace the o-rings without removing the IPR from the HPOP and as long as it's out you might just as well disassemble it the rest of the way and clean out the inside of the valve
http://cw-diesel.com/LuxSite/IPRInfo.htm
  #7 (permalink)
Old 08-12-2009, 09:32 AM
what I ment to say was how do you dissassemble the internals? looks like it threads together but how do you get it apart and is there an other o-ring inside?
  #8 (permalink)
Action4478's Avatar
Action4478 Action4478 is online now
taH ssA
Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE.
To OP , if you take it apart , ignore the pic with the pipe wrench on the threads in Rodney's link. The pipe wrench goes on the small barrel just above the threads in the pic
__________________
Rick.......
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer".... Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
  #9 (permalink)
Old 08-12-2009, 09:52 AM
look scary to me
  #10 (permalink)
Old 08-12-2009, 12:32 PM
RÖENTGEEP's Avatar
FOREIGN GURU
1996 Ford F-250
No there are not another o-ring inside IIRC.
Here is a pic of the O-ring and nut kit:
http://home-and-garden.webshots.com/...46866688MSiehH
__________________
«Primum non nosere»
Tags
73 , 73l , 95 , diesel , ford , injector , international , ipr , kit , navistar , orings , psd , ring , rings , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
