Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-14-2006, 02:59 PM
billb7984 billb7984 is offline
Garage is empty, add now
billb7984 is starting off with a positive reputation.
??? chandler grove carb ajustment ???
Ok guys I have a chandler grove carb on my V-8 flathead,and there is two screws on the back of the carb towards the bottom,is one for the high speed ,and the other one for the low speed,can anyone give me some idea how to adjust these.The truck runs real ruff when it is idling,and sitting still.I know that I am in the wrong area ,but it seems that I can get some better advice here,my truck is a 1947 ,can anyone tell me how many years they made this carb??
thanks for the help guys!!!!!!!! Bill
__________________
billb
  #2 (permalink)
Old 06-14-2006, 04:28 PM
kotzy kotzy is offline
kotzy is starting off with a positive reputation.
Those are both idle mixture adjustments since it is a two barrel carb. At idle
take one side at a time turn it in until it runs really bad and then back it out until it
straightens out, repeat on the other side. Now go thru the same drill again and you should get it to run nice and smooth. You could also turn both screws in lightly against
the seat and back them out 1 1/2 or 2 turns for a starting point.
  #3 (permalink)
Old 06-14-2006, 05:58 PM
instig8r63's Avatar
instig8r63 instig8r63 is offline
instig8r63 is gaining momentum as a positive member of FTE.
Connect a vacuum gauge to an intake vac port and adjust like the above post states. Optimum adjustment will be at the highest achieved vacuum reading on the gauge.
__________________
Bobby
1972 F100 Short Bed 466"/C6 3.50 31 spline
1963 Uni Longbed 390/C6
1967 Mustang Fastback 390 4-speed
Tags
carb, carburator, carburetor, chandler, chandlergrove, company, grove, kit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
