'98 f-150 cruise control not working - Ford Truck Enthusiasts Forums
Old 06-14-2006, 02:57 PM
jason86's Avatar
jason86 jason86 is offline
jason86 is starting off with a positive reputation.
I just bought a '98 F-150 4x4 and the cuise doesn't work. I checked all the fuses and they are all good. Nothing is happening when you try to activate the cruise. What else can I check?
thanks
BTW, It is a 5-spd.
Old 06-14-2006, 03:54 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Several things come to mind:
What is the status of the cruise recall?
Do your brake lights work?
Have you checked F13?
Do your horns work correctly and does your AIRBAG light test properly then stay off?
Steve
Old 06-14-2006, 03:59 PM
jason86's Avatar
I didn't know about the recall until after I posted. My switch is disconnected at the master cyl. I made arrangements with a local dealer to install the parts Friday. Hopefully that is all it needs.
thanks
cruise control not working Orlie 1999 to 2016 Super Duty 86 02-03-2017 08:25 AM
CRUISE CONTROL ISSUE rhamm150 1999 to 2016 Super Duty 3 10-24-2012 09:31 PM
98 F150 Instrument Cluster Dead callman 1997 - 2003 F150 3 06-02-2008 05:01 PM
Horn and Cruise Control stopped working? Stangfire 1997 - 2003 F150 11 03-20-2005 04:58 PM
98 f150 4.6 cruise control and horn wont work keyul Electrical Systems/Wiring 11 02-17-2005 08:28 AM
Tags
1992, 1998, 98, control, controle, cruise, f150, ford, fuse, relay, truck, turn, van, weres, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
