1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Rear spring data for B, F and P codes on 2004 F250/350
Old 06-14-2006, 12:16 PM
mooley's Avatar
mooley
mooley is offline
I'm in need of some F250/350 rear spring data that I'm actually going to use for my 2004 Excursion. I have p-codes on my 2004 F250 SuperCab (PSD) and they seem to ride well for a 3/4 ton truck. Especially with a little weight in the bed, and they would obviously have more weight on them if installed on an Excursion. However, I cannot find anything (I have looked extensively) to tell me what the spring rate, arch, and capacity of p-codes, b-codes or f-codes springs from an F250/350 might be. Anyone have that info or a hint as to where I might look? I'm not sure why I seem to be an oddball with p-codes on my F250 instead of the b-codes as most folks seem to have. My only guess is that it might have something to do with the FX4 package? In any event, I'd like some more info on the p-code, b-code, and f-code springs if anyone has that. Thanks in advance.
Old 06-14-2006, 04:26 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
Hope this helps some...
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Springs
Springs codes are listed as a two-part code. The first character listed is for the front springs. The second code listed is for the rear springs. Auxiliary rear springs may also be listed.
Front Springs — F-Series
Base part number — 5310 (RH/LH)
Pre-fix — F81A
B — Suffix BA
C — Suffix CA
D — Suffix DA
E — Suffix EA
F — Suffix FA
G — Suffix GA
H — Suffix HA
I — Suffix RA
J — Suffix SA
K — Suffix TA
L — Suffix UA
Pre-fix — 1C34
S — Suffix AAA
T — Suffix ABA
U — Suffix ACA
V — Suffix ADA
W — Suffix AEA
X — Suffix AFA
Front Springs — Excursion
Pre-fix — YC35
G — Suffix G
H — Suffix H
S — Suffix S
Pre-fix — 1C34
AG
AH
AJ
Rear Springs — F-Series
L — Rear air suspension
B — 1C34-5560-CB, F-250, F-350
C — 1C35-5560-DB, F-250, F-350
D — YC35-5560-EA, F-250, F-350
M — YC35-5A975-AA, F-450, F-550
N — YC35-5A975-BA, F-450, F-550
Auxiliary Springs — F-Series
A — YC35-5588-A (wide frame)
D — F81A-5588-D (narrow frame)
Rear Springs — Excursion
Base part number — 5560 (RH/LH)
Pre-fix — YC35
A — Suffix A
Pre-fix — 1C34
B — Suffix B
Springs in the Source Book are EXACTLY the same:
Front Leaf 250/350
3600lb 1.12"(thickness) 55.63"(length) 3.00"(width) 350(deflection)
4000lb 1.18"(thickness) 55.63"(length) 3.00"(width) 370(deflection)
4400lb 1.18"(thickness) 55.63"(length) 3.00"(width) 390(deflection)
4800lb 1.18"(thickness) 55.63"(length) 3.00"(width) 410(deflection)
5200lb 1.18"(thickness) 55.63"(length) 3.00"(width) 430(deflection)
6000lb 1.25"(thickness) 55.63"(length) 3.00"(width) 470(deflection)
Rear Leaf 250/350
6830lb 6(leaves) 3.86(thickness @ pad) 58.1"(lenght) 3.00"(width) 320/670/1209(deflection lbs/sq") 3603(rating@pad lbs/spring)
Super Duty Series/Model: F-250/F-350 SRW Pickup
Combined Rating @ Ground: 6830 pounds (lbs.)
Number of Leaves: 6
Total Thickness @ Pad: 3.86 inches (in.)
Overall Length: 58.1 in.
Width: 3.00 in.
Deflection Rate (lbs. per in./ spring): 320/670/1209
Rating Each @ Pad (lbs. per spring): 3603
Front Suspension:
Non-independent rigid axle with stabilizer bars (4x4) 5200#
Leafs - 3600-6000# (4x4)
Rear Suspension:
Non-Independent live axle, leaf springs and shock absorbers.
Camper Package & DRW includes sway bar
Leafs - 6830# F-250 & F-350 SRW
Old 03-31-2008, 01:07 AM
Richard_cranium's Avatar
Richard_cranium
Richard_cranium is offline
I too have spring code TP I can't find anything that would tell me what the P represents and it's not in the tech folder. Any help would be greatly appreciated
Old 03-31-2008, 11:27 AM
Richard_cranium
Bump for the refresh?
Old 03-31-2008, 01:45 PM
Richard_cranium
So no one has any Idea why this is a code "P"??????
I know there isnt anything rubbed off and It deffinatley says P so does any one have any idea who I could talk to to find out???
P.S. I recieved my build sheet today that was no real help either
Old 04-01-2008, 02:49 PM
Richard_cranium
For what It's worth.
I went to the dealer today, They searched using my VIN # and were able to tell me that My "P" code stands for 8,800# rear springs.
Ford Part # 3C34-5A973 CC
Powersmoke_sd
04-04-2017 11:44 AM
BII Plow Truck
2017+ Super Duty
02-17-2017 01:52 PM
hstechteacher
04-04-2016 10:50 PM
Eric H
04-14-2013 11:06 AM
Quick Reply: Rear spring data for B, F and P codes on 2004 F250/350
