timing belt pulley... bolt size?
Old 06-14-2006, 10:44 AM
jjjcab's Avatar
jjjcab
jjjcab is offline
All,
Great site.....have been reading for years regarding my 97 Expy and 93 Ranger.
I'm changing the timing belt (busted) and need help with the socket size for the bolt holding the crankshaft / timing belt pulley on. Tried 21mm but its too small. Before heading to the parts store yet again.....thought I'd ask you folks.
Many thanks,
John
Old 06-14-2006, 01:23 PM
Bart99GT's Avatar
Bart99GT
Bart99GT is offline
It should be a 22mm socket.
Old 06-14-2006, 03:31 PM
jjjcab's Avatar
jjjcab
jjjcab is offline
22mm did the trick....thanks a lot! Now to break it loose....
Regards,
John
Old 06-15-2006, 12:04 PM
Bart99GT's Avatar
Bart99GT
Bart99GT is offline
Its generally torqued to about 120-140 ft/lbs, it can be a pain to remove the first time. Usually a breaker bar with a cheater will break it loose. If you reinstall it to about 100 ft/lbs it will stay in place and won't be such a pain to remove the next time around.
Big Skier
31
02-27-2019 07:21 AM
trotsky13
28
11-29-2009 07:04 PM
John Blasko
1997 - 2003 F150
10-07-2005 01:09 AM
imlowr2
10-02-2004 11:38 PM
Quick Reply: timing belt pulley... bolt size?
