lights
Old 06-14-2006, 08:32 AM
dlskinner's Avatar
dlskinner
dlskinner is offline
Question lights
I have a f 150 that my lights will not turn off after the engine has been started and I have no running lights. where due I start looking for the problem?
Old 06-14-2006, 10:47 AM
tdister's Avatar
tdister
tdister is offline
First make sure tha "auto lamp" switch is turned off if you have it. It will be to the far right of your headlight switch, one of the "wheels". The sensor for it can get dirty or covered by something and it will always think it's dark out, it also has sensitivity adjustment thru the ****. The sensor is in the middle-top of the dash (tiny grill).
Old 06-14-2006, 12:02 PM
dlskinner's Avatar
dlskinner
no auto headlight switch
Thanks but my truck does not have the auto headlight switch.
This problem occur when I brought my truck back from the dealer
A recall for the speed control module. dealer sez they had nothing to do with the headlights.
Old 06-14-2006, 02:18 PM
tdister's Avatar
tdister
tdister is offline
I know this has been solved before, but I can't remember the answer.
For the sake of others who can maybe help: Is it just the headlights or are the side markers and tail lights on also?
Old 06-15-2006, 04:03 PM
dlskinner's Avatar
dlskinner
headlights
Thats correct my tail dont work at all after starting the truck.
headlights work correctly before the motor is started.
Once the motor is started
(as soon as the light switch goes to parking light position,
which is the position on the light switch before lights.)
The headlights come on and parking lights and taillights due not come on.
Thank You
Old 06-16-2006, 12:19 PM
doctor-rv's Avatar
doctor-rv
doctor-rv is offline
Smile
Check all fuses(of couse) and any connectors under dash that may have been up-plugged by dealer. This sounds like a possible relay problem but is probably due to something the technician did at the shop. It is common for them to tell you that it couldn't be related but the fact is you never had this problem before you took it to them. Try calling back and talking to service manager about this. Be firm but curtious. Don't let them shuffle you out the door. If it comes to it, demand they at least take a second look at the work they did and see if could be related. At worst you will waste some of your time. Good luck!
Old 06-18-2006, 05:22 PM
dlskinner's Avatar
dlskinner
I will take your advice
I will take your advice.
I havent thought about the wiring under the dash.
Thank you.
AirMakesMeCrazy
02-15-2014 08:48 PM
regenhater
Electrical Systems/Wiring
01-20-2014 07:32 AM
Whiteknuckler
09-17-2011 01:06 AM
LARIAT 85
22
10-24-2009 09:14 PM
Quick Reply: lights
