Comp Xtreme 4x4 cam, anyone? - Ford Truck Enthusiasts Forums
Old 06-13-2006, 08:51 PM
bowser bowser is offline
bowser is starting off with a positive reputation.
Question Comp Xtreme 4x4 cam, anyone?
Getting my 400 ready to go, and can't use the old Crower that was in the 351M I took out. Had flat spots on a few lobes. I know that the DEH cams are the standard, but I was wondering if anyone had tried this cam. The engine I will end up with has +.030 bore, stock piston, stock head machined for roller rockers, edelbrock intake, holley 4bbl, headers and dual ex. I will also be adding a new double roller timing set, and the correct springs. I bought a complete long block, so I can get by without the K-kit. I was wondering if anyone had ran one of these 4x4 cams recently, or if someone could help me understand if it would be any better or worse than one of the DEH cams. Here's the numbers I got for it, and the 255DEH and 265DEH to compare:
Duration @ .050 lift Lift w/1.5 ratio Lobe
RPM IN EX | IN EX | IN EX | sep
X4x4
1000- 256 262 | 210 218 | .514 .514 | 111
5000
255DEH
1200-
5500 255 265 | 203 216 | .469 .495 | 110
265DEH
1500-
5750 265 275 | 211 223 | .484 .514 | 110
What would be the pros/cons of the xtreme vs the DEH in my setup?
Thanks in advance
brent
Last edited by bowser; 06-13-2006 at 08:58 PM. Reason: trying to get the chart to look better.....
Old 06-13-2006, 10:31 PM
danlee's Avatar
danlee danlee is offline
danlee has a good reputation on FTE.danlee has a good reputation on FTE.danlee has a good reputation on FTE.
I like the 265DEH for towing at highway speeds, but for low RPM grunt, the 255DEH is better. This is the first I have seen the XE 4x4 cam. It has a little more lift than the 255DEH, but the stock heads don't flow much more above 0.450" lift.
Dyno sim gives the XE an advantage at 2000 RPM with 438 ft-lb torque, while the 255DEH gets 430 ft-lbs@2000. The 255DEH is a little flatter, and produces 298 HP@4000 RPM, while the XE has 297 HP@4000 RPM.
I think that the 4x4 XE is a slightly better cam, and could be much better with some head porting so the heads flow better at higher lifts.
Old 06-14-2006, 06:16 AM
Cool, thanks danlee. I doubt my truck will tow very much, so it will be a toss-up between the 4x4 and the 255 for me. Decisions, decisions......
Old 06-14-2006, 09:18 PM
guess it would help if i read the whole page. that specific cam that i was looking at is for the 460. wonder what it would cost to get.... nah the DEH is cheaper and just as good. Thanks again for running the numbers danlee.
Old 06-14-2006, 09:27 PM
danlee's Avatar
460? Why the high lift? Stock 460 heads don't flow as good as stock 335 series heads at high lifts.
For best results you want a custom hydraulic roller with the timing of a 255DEH, and more lift, also ported or aftermarket heads.
Old 06-15-2006, 11:56 AM
BroncoChuck BroncoChuck is offline
BroncoChuck is starting off with a positive reputation.
Maybe I am not looking in the right catalogs, but I thought they didn't make this cam for a 400? Is this a new offering or am I retarded?
Old 06-15-2006, 01:03 PM
danlee's Avatar
It is for the 460, not the 400.
Old 06-15-2006, 05:07 PM
Munch Munch is offline
Munch is starting off with a positive reputation.
Ive got the XE 262 in my 78F250. Believe this but ive got the same engine set up as what you described except I have a carter 625 for a carb. So far im very happy with this cam. its got lots of torque, and sounds nice at an idle.
Old 06-15-2006, 06:01 PM
Quote:
No, I was retarted. It is for the 429/460. I didn't pay attention to what the chart said at the top.
Munch, thanks for the report.
Old 06-16-2006, 10:18 AM
OOPS......I saw the 460 comment a coupla posts before mine. Too bad I didn't see it before I posted. The coffee wasn't consumed early enough I guess....
Old 06-16-2006, 12:55 PM
i know the feeling......
'09 XL rear speaker wiring? CtCarl 2009 - 2014 F150 1 02-07-2016 04:54 PM
In Dash Head unit fitment (Pioneer DEH-X3600UI) alchemist1 1973 - 1979 F-100 & Larger F-Series Trucks 18 08-03-2014 12:35 AM
Compcams XE256H 78-250Super 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 5 08-20-2007 07:32 PM
Thoughts about Comp Cams XE262 for 428 build dbossman FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 1 04-05-2006 08:39 PM
1990 460 Lifter problem 351M Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 9 08-03-2005 01:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
