New Oil Pump, Still Low Pressure
I just finished a cam and intake swap on my 400. Gave it a new Melling OEM oil pump, and it still lacks strong pressure. She cranks out 50 to 60psi at start-up, but after it gets warm, she drops to 5 to 10psi at idle, and 20 to 25psi cruising. Not really enough to make me feel warm and cuddly inside.
78 f250 4x4
400 auto
78 f250 4x4
400 auto
It's a common problem. It is usually caused by too much oil to the lifter galleries. To solve it you should install restrictors in those gallery ports. However that requires nearly complete disassembly of the motor.
You shouldn't be overly concerned about it, because the oil pressure is measured after all the mains have gotten oil. The only part that gets oil after the oil sender is the valve train on the drivers side.
External oil line
Regarding an external oil line:
What are the different ways to do that? Expensive looking hose or can just pipe be used?
I'm giving my 400 a quicky rebuild with a new oil pump and timing set and would like to do this little trick to help with the rear main oil problem I hear about.
Any insight would be appreciated. Thanks, Gier-head
exbxtoy
66
09-22-2020 10:35 PM
FERacing66
13
06-01-2020 05:16 PM
brain75
31
02-05-2016 06:01 PM
JJDDOOGG
01-17-2003 09:09 AM
