Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-12-2006, 05:44 PM
Hotwheelbill's Avatar
Hotwheelbill Hotwheelbill is offline
Garage is empty, add now
Hotwheelbill is starting off with a positive reputation.
First filter of WVO.
If anyone remembers, I got ahold of 300 gal. of prime oil from a 3 day shimp fest. It has been sitting for over 4 weeks now and I found the time to build my home filter kit. Pump from Harbor Frieght $25.00 on sale and $9.95 for a two year replacement warranty. Home Depot G.E. home filters,two, with 15 micron filters,$32.00 each. Lowes hose and fittings about $40.00. Ace Hardware gauges,two, $5.65 each. Drums 6x $36.00 each. Salt and baking soda from Sams. I have just kind of bought what I have a little at a time. I still need two check valves on the pick up hose and maybe a pre-pump screen. BTW, check to make sure your filter housings are tight out of the box!!!!
I plan to fill the 55 drum today and let it sit for three weeks with the salt and bs. Then I will heat it, but , it is 95 here already. Water test shows no water, but I still want to heat it to 140 for a little while ,cool and filter the last time with 1 micron filters.
I have to now add that I now have water in my oil. I was not watching the hose and sucked from the bottom of one of the drums......milk! I also think that I will fab a pcv pick up 1" dia. with a closed end and screened pick up about 18" from the closed end, then a check valve, then another 24" of 1" pcv and reduce to hook up to my 3/4" hose. This will keep me from, 1) holding the hose,2) pulling from the bottom. 3) allow me to suck from one of the bung holes and not have to pull the lid.
The first filter is ready to change I think...50 gal. The PSI on that filter was up to 45 psi. and the second filter was only 25psi and very GOLD!!!!!
Any input will help. Thanks.
http://i63.photobucket.com/albums/h1...ll/filters.jpg
http://i63.photobucket.com/albums/h1...l/91e8b211.jpg
http://i63.photobucket.com/albums/h1...bill/drums.jpg
__________________
03, CC,F350,DRW,SB,4WD,7.3,AFE II Pro 7,CCV MOD,THREE GAUGES,4739, DP TUNER with Permagrin setting, 5" Cannon, Zodad, AIH Delete, Power Slots, Hawks. TCLUS. Coolant Filter, Sonnix, Fuel Pump Shim.....SOLD
  #2 (permalink)
Old 06-13-2006, 06:40 PM
14psd's Avatar
14psd 14psd is offline
1995 Ford F-350
14psd is starting off with a positive reputation.
Hey Hotwheelbill, Let my know how well your pump does at drawing up the heigth of your barrel. I have the same pump and it didn't like sucking that far up so I put a hole towards the bottom of the barrel and now I get great results, as far as pumping the oil. I'm still trying to get better filtration. I still get that crap in the bottom of the fuel filter bowl of my truck. I also us the bag filters from mccarter.com down to 1 micron and I still get the crap.
__________________
Todd______________________________________________ __________________________________________________ ______________________________
'95 F-350 daully, Super Cab, 254K+ miles, 2wd, auto, Bean's stage 1s,shimmed fpr, 3" down pipe, superchip, gauges boost, EGTs, trans, and volts, missing Kitty & muffler, Homemade tymar set-up, HPX mod, CCV mod, and air bags in the rear SLAPS member
  #3 (permalink)
Old 06-14-2006, 01:32 PM
Quote:
Are you running the WVO thru you stock diesel fuel line?
__________________
  #4 (permalink)
Old 06-14-2006, 05:00 PM
14psd's Avatar
1995 Ford F-350
yes I am, I'm hearing that, that might not be the best idea
__________________
Tags
diesel, filter, truck, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
