2.3L distributor differences? - Ford Truck Enthusiasts Forums
Old 06-12-2006, 12:28 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Hey guys! Never been in this forum before!
I have a question about 2.3L distributors. I have a mallory distributor that I thought would fit a '89 OMC boat motor. (not mine, and the guy who has it now says it won't fit).
Without going into details, it doesn't fit the hole in the block.
Is there a difference between the industrial motors and the automotive motors?
Anyone out there with a 2.3L automotive distributor that would take measurements of the length of shaft, size of the oil pump drive, how many teeth on the gear (and diamter), and the diamater of the housing where it goes into the block?
Thanks in advance for any and all information !
Old 06-13-2006, 02:06 AM
TigerDan's Avatar
TigerDan TigerDan is offline
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
Hey Art! Slumming, I see...
As far as I know, a 2.3 is a 2.3. I'm wondering if the dist. you have is made for the early ('71-74) 2.0 which takes a smaller distributor. I can't lay hands on any 2.3 distributors for measurements on short notice, but if no one else gets back to you I can get one in a day or so, all my 2.3 stuff is at my co-worker's house since he's building a mini-stock.
Old 06-13-2006, 09:15 AM
Krewat's Avatar
I have (will have, had, etc) a Mallory single-point distributor.
It's a model # YL-679A
The guy who is returning it to me said it doesn't fit his '89 OMC motor.
While I do notice that the drive gear may have less teeth than an automotive, I can't be sure until it's back in my hands again.
Mallory says it fits Ford 2.3's, it's a Marine distributor because of the spark screen, etc. etc.
Maybe it's time to visit the auto parts store and see if they have any 2.3 dizzies in stock to compare.
I appreciate the attempt at measurements, if you can, please do that without putting yourself out.
thanks!
Old 06-13-2006, 09:44 AM
TigerDan's Avatar
I looked on Mallory's website and I can't even find that much info, just a 3-yr-old support ticket from a guy saying he has one with problems and it's listed as being for a 4-cylinder industrial engine.
Here's a pic of a stock unit so you can at least visually compare:
Old 06-13-2006, 10:41 PM
jimdandy jimdandy is offline
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
89 does not have a vacuum advance. It is electronic. I don't know if the dist housing is different tho. jim d
Old 06-14-2006, 08:20 AM
Krewat's Avatar
Hmm... it does look slightly different. Shaft is slightly smaller, gear has less teeth.
I guess it's off to the auto parts store...
Old 06-16-2006, 10:03 AM
TigerDan's Avatar
Okay, here are some dimensions:
Total length of shaft from block flange surface on housing (just above the o-ring) to end of shaft: 3 3/8"
Diameter of housing flange that goes into block: 1.300"
Length of same: 1 1/4"
Diameter of gear: 1.225"
Tooth count: 18
Shaft diameter: .515"
Oil pump hex shaft: 5/16"
Hope this helps.
Old 06-16-2006, 01:57 PM
Old Rob Old Rob is offline
Old Rob is starting off with a positive reputation.
The TFI IV dist are longer from the gear down for the oil pump drive shaft. Totally interchangable.
Old 06-16-2006, 02:05 PM
Krewat's Avatar
Dan, you're the best! Here's the measurements I can get with a ruler (dial calipers are out in the garage). Looks like it's an industrial one, that's for sure.
Mallory: 3 3/4"
Mallory: 1 3/8" (1.375)
Mallory: 1 1/2" from flange to bottom of aluminum billet.
Mallory: 1 3/8" approx.
Tooth count: 18
Mallory: 12
Mallory: 7/16" (.4375) approx.
Mallory: 1/4"
This is a Mallory YL-679A
Old 06-16-2006, 09:24 PM
TigerDan's Avatar
The only info I can come up with in that part number is that it's for a 172 CID (2.8L) Ford Industrial 4-cylinder as used on tractors. Not for a 2.3 from the sound of it!
Old 06-16-2006, 10:08 PM
Krewat's Avatar
Hmm... and I saw a Mallory listing that showed 2.3...
Industrial though, that makes sense
351 W distributor question Bluetorpedo 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 25 08-14-2016 03:15 PM
Distributor Issue D.K 1987 - 1996 F150 & Larger F-Series Trucks 4 10-19-2015 05:16 PM
Replace PIP or Replace Distributor? DesertZuki 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 03-04-2015 12:16 PM
Bronco II leaking oil from Distributor HELP!!!! mike93082 Bronco II 10 01-24-2006 11:12 PM
89 Ranger Dual Plug distributorless gUiTo1969 Ranger & B-Series 1 03-17-2004 06:07 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
23, 23l, cylinder, dist, distributor, engine, ford, industrial, mallory, mallroy, marine, omc, points, vacuum, www
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
