Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-09-2006, 04:32 PM
hillbilly2thru9 hillbilly2thru9 is offline
Garage is empty, add now
hillbilly2thru9 is starting off with a positive reputation.
flatty 8 won't fire
can somebody please tell me why my '50 Merc' flatty won't fire? We checked the wiring, put a new 6 volt battery in, made sure the engine was free, thinkin' it might be the wall mounted solenoid, but don't know, the top of the solenoid clicks when we put a screwdriver against it, any info would be appreciated
  #2 (permalink)
Old 06-09-2006, 07:46 PM
scottie2hottie's Avatar
scottie2hottie scottie2hottie is offline
scottie2hottie is gaining momentum as a positive member of FTE.
wont fire or wont turn over? big difference....
__________________
2002 F350 "Big White"
2001 F150 "Black Pearl"
1996 F350 "Red Sled"
Proud to be an OHIO BOY
  #3 (permalink)
Old 06-09-2006, 08:13 PM
i seem to be getting fire from the battery and the starter solenoid,but it does not seem to be getting fire to the starter to crank the engine,i am not used to the 6 volt system,that seems to be my problem ..someone told me that the grounding system was reverse ground,is this also correct?....thanks... hillbilly2thru9
  #4 (permalink)
Old 06-09-2006, 09:28 PM
jeffh's Avatar
jeffh jeffh is offline
jeffh is starting off with a positive reputation.
It's positive ground, not negative ground like modern vehicles. Make sure the battery and starter cables are in good shape and have clean, solid connections. Do the lights and horn work?
__________________
1950 F3 -- "Big Tank"
Missouri chapter member
  #5 (permalink)
Old 06-09-2006, 10:50 PM
thanks jeffh, the headlights do but the taillights don't and the horn works, and the other day, when we first hooked up the battery, one of the headlights smoked out. i'll check the starter cable in the morning...thanks...hillbilly2thru9...
  #6 (permalink)
Old 06-23-2006, 10:29 AM
getsch58 getsch58 is offline
getsch58 is starting off with a positive reputation.
hows the cylinder compression?
  #7 (permalink)
Old 06-25-2006, 01:04 AM
51ford fan's Avatar
51ford fan 51ford fan is offline
51ford fan is starting off with a positive reputation.
My Flathead 6 had that problem it turned out to be the stud through the Distributor the primary wire goes to. There is a plastic washer that had failed and allowed it to ground out.
Rod 51F1
__________________
Rod 51 F1 Truck
Flathead 6 / 3.23 Rear
S-10 5-Speed
"Keep on Truckin"
  #8 (permalink)
Old 06-25-2006, 10:06 PM
thanks, getsch58 and 51ford fan! and everybody else that's helped me and my brother try to get the ol' Ford runnin',we will check that out in the mornin' and get back to y'all, sorry for not gettin' back sooner, been drivin' trucks...
  #9 (permalink)
Old 06-26-2006, 06:56 AM
Just hope you can figure it out. Sucks when you can't drive the car/truck.
  #10 (permalink)
Old 06-28-2006, 06:30 AM
stuart1 stuart1 is offline
stuart1 has a good reputation on FTE.stuart1 has a good reputation on FTE.
http://www.btc-bci.com/~billben/flathead.htm
__________________
Wrench twister since 1957.
Journeyman since 1964.
Transmission builder since 1964.
  #11 (permalink)
Old 06-28-2006, 08:41 PM
kotzy kotzy is offline
kotzy is starting off with a positive reputation.
Take a jumper cable and go from the negitive battery post to the stud that the wire from the starter to the solenoid connects to. Does the starter crank the engine? If not
go right down to the stud on the starter, crank now? If it doesn't I would figure a starter problem.
  #12 (permalink)
Old 06-28-2006, 08:43 PM
  #13 (permalink)
Old 06-30-2006, 03:47 PM
John2Thomas John2Thomas is offline
John2Thomas is starting off with a positive reputation.
Make sure the truck is out of gear before you try this.
  #14 (permalink)
Old 07-03-2006, 02:10 PM
captchas's Avatar
captchas captchas is offline
2013 Ford Escape
captchas has a very good reputation on FTE.captchas has a very good reputation on FTE.captchas has a very good reputation on FTE.captchas has a very good reputation on FTE.
if it was sitting along time there is a good chance the starter it self rusted up solid . and do as above the old 6 volts most have great solid grounds to work correctly
  #15 (permalink)
Old 07-03-2006, 08:11 PM
thanks, captchas! and everybody else who have helped us on our project. i took the starter off and took it apart and one of the wires had broke loose, so we sent it to a local starter shop. when we get it back, we will try it out...thanks, again...hillbilly2thru9...
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
