Fuel Consumption at High Idle - Ford Truck Enthusiasts Forums
Old 06-08-2006, 11:20 PM
Jim McCarty's Avatar
Jim McCarty Jim McCarty is offline
Jim McCarty is starting off with a positive reputation.
Smile Fuel Consumption at High Idle
I had the outfitter switch (cheap) fast idle installed. I used switch #3 (10A) and the BCP wire. It really works great and cost $75 for a professional mechanic to wire it. It runs a steady 1200 RPM and the EGT stays right at 415 in the manifold.
The question is does anyone have any idea how much fuel per hour it will burn at 1200 RPM?
Old 06-09-2006, 02:01 AM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
The numbers I've heard is 2 gallons per hour. I don't have any scientific evidence to back that up, but it seems to be pretty close on my truck.
Old 06-13-2006, 12:48 PM
laredo7mma's Avatar
laredo7mma laredo7mma is offline
laredo7mma is starting off with a positive reputation.
I meant to reply earlier, sorry about that.
I can't remember the exact numbers, but high idle when the engine is cold uses alot more fuel than when the engine is warm. I want to say 1.5 gallons per hour when warm, but i will check tonight after the drive home from work.
I think the reference that tvsjr is talking about is that idling for an hour is like driving 33 miles. My truck when warm, no AC, and in park burns 0.5 gallons per hour. That bumps up to 0.8 gallons per hour when your are in drive with your foot on the brake. The 0.5 gph in park also jumps to 0.8 gph when you turn on the AC. I see no difference in mpg driving at highwat speeds with the AC on or off.
Check out the scangauge thread on this site. It is a great little tool.
Old 06-13-2006, 04:25 PM
6L PWR 6L PWR is offline
6L PWR is gaining momentum as a positive member of FTE.
Quote:
WOW!! I'm glad I did it myself. Only took me 10 minutes once I got the upfitter switches in. Mine didn't come with them, but I found them online for $80 and put them in and set up #4 for the high idle. I don't know why, it just sounded cool. No reason for me to use it.
Engine misfire daddylee100 1987 - 1996 F150 & Larger F-Series Trucks 4 09-07-2015 09:08 PM
What RPM is 'high idle'? andysam 6.0L Power Stroke Diesel 9 04-29-2014 09:21 PM
Did the high idle mod but... ROBBINthaHOOD 6.0L Power Stroke Diesel 6 10-16-2011 06:48 PM
1997 F350 7.5L has rough idle when cold lauraj 1987 - 1996 F150 & Larger F-Series Trucks 5 02-14-2011 03:34 PM
Miss at idle and 1200 rpm apeman426 1999 - 2003 7.3L Power Stroke Diesel 7 10-07-2008 06:37 AM
Tags
67, 69, consumption, deisel, diesel, engine, ford, fuel, hour, idle, idling, pickup, ranger, truck, usage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
