c6 tranny swap
c6 tranny swap
The aod tranny in my 90 bronco is on its last days. I have a c6 from my 86 F-250 that i would like to replace the aod with, but my only question is will the borg-warner t-case from the bronco bolt up to the c6 or will I have to buy an adapter or swap in the np t-case from the f-250 as well.
Easiest way to figure out if the t-case will work is to crawl under the bronco and see what the mouting patern is of the Aod and compare it to the c-6. I could mate a c-6 up to the same transfer case that was orginally behind an E4OD because the '88 c-6 happened to have the same circular bolt pattern as the '91 E4OD.
Milwaukee1979F150
11-23-2009 05:58 PM
