05 Explorer - Gas gauge not working - Ford Truck Enthusiasts Forums
Old 06-08-2006, 02:48 PM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
went out truck was fine, started the truck to come back and the service engine light came on, and within about 30-sec the gas gauge went to E...
Is there a way I can get codes without a scanner?
Thanks,
David
Old 06-09-2006, 07:05 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile CowboyBilly9Mile is offline
CowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to all
You have OBD-II, there is no way to extract codes without a scanner. Autozone, in anticipation of your buying parts from them, will pull codes for free if the CEL is on. But on an 05, why not just schedule a service visit and use that factory warranty.
Old 06-09-2006, 07:03 PM
Did schedule service. They told me 1 wk... Plus they are the closest Ford dealer and they're like 30 miles away... If they were closer I'd probably just drop in and hound them...
Just would like to know what's going on... It's my father's truck and I'm visiting till sunday. His idea of maintenance is to fill up the gas tank... I'd like to know the truck will get what it needs...
Oh well.... He's not worried, so I guess I won't worry. It feels like it has a very slight miss... which it shouldn't with 16k on it. He said the CEL was on before and went off. Intermitant missfire will do that. I'll bet the dealer says bad gas...
Thanks.
David
Old 06-09-2006, 09:23 PM
vloney vloney is offline
vloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant future
as a suggestion, get an additive called techron from chevron. Ford has a tsb on that to correct fuel card contamination from sulfur in the fuel. Might not fix it, but why not get the jump on them?
Old 06-09-2006, 09:35 PM
1081's Avatar
1081 1081 is offline
1081 is starting off with a positive reputation.
Is it still under warranty? If it is, let Ford do it.
Old 06-09-2006, 11:12 PM
whimsey whimsey is offline
whimsey is starting off with a positive reputation.
The wife has a 2005 EB Explorer 4.6L V-8 and had the same problem. It required the dealer to drop the gas tank to fix the problem. Unless you have a ***** load of miles on your 2005 so it's not under warranty, let the dealer fix it on Ford's "nickel", not your's.
Whimsey
Old 06-10-2006, 12:58 PM
I am letting ford fix it, I just like to know what's up. I've been given the dealer runaround before...
Thanks,
David
Old 06-10-2006, 07:41 PM
njf207 njf207 is offline
njf207 is starting off with a positive reputation.
I know this is a common problem. My friends wifes explorer had the same problem they had replaced the sending unit several times and still did not cure the problem and they had to replace I think the gage cluster in the dash and thats what cured the problem that took months to fix.
Old 10-19-2006, 09:55 PM
bmx045 bmx045 is offline
bmx045 is starting off with a positive reputation.
sorry to bring up the burried thread but...my 05 is doing the same...my aunt gave the truck to me and filled it up previous to giving it to me. That night the gas gauge dropped to BELOW E mark and stayed there, it jumped back up when the gas level was below 3/4. This will trigger a CEL. However Ford did tell me it was "bad gas" and to use Chevron Techron(didn't help...).
When you fill the tank above 3/4's it will error, but below that my gauge works fine, and the CEL will go off. Must be a bad sender....and they did mention the dirty fuel card.
Is making a fuel tank gauge that difficult? Manufacturers have been making flawless gas tank gauges/sending units for decades and yet Ford needs to change the technology..making it all electronic..and now are adding even more TSB's and recalls that shouldn't be necessary in the first place! (IMO).
Old 10-20-2006, 10:25 AM
Dealer told my father the same thing. Use Chevron gas... He's still having the same problem. He's going to get them on the lemon law. He's just going to keep bringing it back for the same problem over and over and play dumb. Then after he's got 4 or 5 repair slips and the problem comes back...
Old 10-20-2006, 04:02 PM
Yeah I'm not too worried about it, it is under warranty. I just don't have time to bring it in, but I'll make a point of it soon. They said to use chevron techron fuel additive, not the gas.
Old 10-20-2006, 09:13 PM
The additive works, it isnt instant, possibly 2 or 3 tanks. The problem is the fuel. This will change with the governments mandate on sulfur ( no, its not just diesel ). Yeah, changing the sending unit will fix it too, until the fuel screws up the new one as well.
Old 10-20-2006, 11:42 PM
Well I noticed that it's only at the upper portion of the sending unit, up around the 3/4 - full mark on the sensor...I was just hoping it would relieve itself with time.....
Old 10-21-2006, 08:35 AM
Joe B Joe B is offline
Joe B is starting off with a positive reputation.
I had a problem with the gauge a few times.The needle would go up by the next day.
I read on another Explorer forum to take the key out of the ignition when filling with gas and never had a problem since on my '05.
Old 10-27-2006, 07:21 AM
kram1 kram1 is offline
kram1 is starting off with a positive reputation.
All of the above are valid...I experienced all of them including the key on the ignition while filling up. Eventually, I had my sending unit, fuel pump replaced (warranty) by the delearship two weeks ago. I have since filled up gas and the problem did not occur...so far so good.
Does anyone know anything about 1973 Ford trucks? mountain dewd 2004 - 2008 F150 1 01-18-2016 10:31 PM
1990 ford alt/gas gauges not working wahlturfcare 1987 - 1996 F150 & Larger F-Series Trucks 0 12-23-2015 03:55 PM
Smoke coming from gauge!?! Planejet42 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-10-2015 11:37 PM
69 f100 gas gauge and oil temp gauge not working gabestalker 1967 - 1972 F-100 & Larger F-Series Trucks 6 05-27-2014 02:46 AM
Gas Gauge Not Working '94 F250 3spd 1987 - 1996 F150 & Larger F-Series Trucks 2 09-17-2010 06:25 PM
Tags
01, 05, 2003, 2005, explorer, fix, ford, fuel, gage, gas, gauge, inoperative, sports, trac, working, workingexplorer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
