concrete vs. blacktop
#31
I just moved to Minneapolis and they use asphalt here almost exclusively. The reason? Because on a 20 degree day, concrete will hold ice--the black asphalt will gather enough heat from the sun to melt it. Kind of strange to see snow & ice everywhere and then perfectly clear and dry driveways.
#33
#34
For a bit more than poured concrete you can get concrete pavers. I like Grinnell brand. http://www.grinnellpavers.com/ To me its much nicer looking than a slab. I used them for a patio and when the asphalt driveway is shot I won't hesitite to use them there too.
#35
#37
Another nice thing about concrete is that you can use an epoxy finish on it to prevent spills from soaking in.MUCH easier to clean up.Put in a center drain with the floor gently slpoing to the center,and hose it down and all the water goes to the drain without a lot of squeegy work.Do it at night befire you go in the house and it is dry in the morning.Can you tell I`m a bit lazy?Hehehehe.
Leo
Leo
#38
The epoxy coating thing would be great, escpecially on an outside pad in an area where water absorption/freezing can result in cracking. I just epoxy coated the entire basement 3-car garage in the house I just moved into... this time, before unpacking my shop. Boy!! It's a great surface... almost makes me WANT to sweep it.... ALMOST!!
#39
#41
I have a well poured and non cracked 10 year old concrete drive. If you go concrete, just keep a bucket of portland cement around in case someone with a oil leaking car comes around. Just sprinkle a nice amount on the spill and let sit for a day. Cleans pretty. Also, do a search for "pour and restore" driveway cleaner. I bought some but haven't tried it yet. An I only give "leakers" one freebie. These folks are told to stay off the drive in future visits.
#43
I've never done a concrete or blacktop driveway before but three of my neighbors just had blacktop driveways done, shortly after the job was done they sprinkled the entire surface with a concrete powder mix that helps to seal the surface and now you really can't tell it's not concrete, I've always preferred the look of concrete.
#44
I'd go with 5'' concrete pad (with rebar and 6 x 6 wire) that's "big enough". And then put gravel (AB3) down. Black top is a waste in my opinion. Gravel is easy to maintain on fairly level ground especially if you have a rear blade on a tractor. But if money is no object, do the whole thing in concrete with Interstate specs.
#45
Originally Posted by afinepoint
I have to throw the flag on a 3' deep driveway pour. 6" is suggested and is more than sufficient for any homeowner.
The concrete salesman must have called the home office on that one.
