Stump removal and what kinda tree is this?
Old 06-07-2006, 09:14 PM
jake00's Avatar
jake00
jake00 is offline
FTE is my crack
here's my stump / tree
http://www.fortjake.com/fte/tree.jpg
Any Idea what kinda tree it was?
I'll have a scan of a leaf tomarow hopefully (a good portion of it was rotted very badly)
Old 06-07-2006, 09:17 PM
fordsuvparts's Avatar
fordsuvparts
fordsuvparts is offline
Get a close up picture of the bark and the grain pattern and i can tell you what it is, a leaf never hurts either. Plan on renting a big stump grinder that is pull by you truck.
Old 06-07-2006, 09:18 PM
Bdox's Avatar
Bdox
Bdox is offline
Get someone with a heavy backhoe to pull that thing over, breaking off the roots below ground.
Old 06-07-2006, 09:20 PM
Beast12's Avatar
Beast12
Beast12 is offline
I am assuming that is the rotten tree you posted about a few months ago? If so, I still say it is a Silver maple. They get to around that size and start to rot. Good call on getting it cut down.
If that truck was cut down to just above the ground and those rocks were gone, I would guess at approximately $150-200 would have that stump ground out for you. All that would be left it a big pile of woodchips. Great for the garden.
DO NOT try to dig or pull it out. Much cheaper and easier just to get it ground out. To grow grass over the hole afterwards you need a minimum of 4" of soil. So make sure the tree company grinds it down a minimum or 4" (6" is better). The roots are ok if they are 2" down.
-Matt
Old 06-07-2006, 10:45 PM
cmpd1781's Avatar
cmpd1781
cmpd1781 is offline
Good call on the maple, "beast"........Just collected some maple (silver) for firewood and looks just like that. It's a good burning hardwood, but not as straight and DAMN sure not as easy to split as good ole' oak.........
Old 06-07-2006, 11:11 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
I have two like that I need removed. Silver maples grow fast but they are a PITA with all of the helicopters and leaves. I have 5 silver maples in the yard.
Oaks are a pain also. They lose half their leaves in the fall, 1/4 throughout the winter and the last 1/4 in the spring along with the "flowers" that clog gutters. The leaves take forever to decompose. I only have one oak tree.
I have to clean the gutters three times each year. They need cleaning again now.
Old 06-07-2006, 11:28 PM
FTE Herman's Avatar
FTE Herman
FTE Herman is offline
I thought it looked like cherry.
Old 06-07-2006, 11:41 PM
jake00's Avatar
jake00
jake00 is offline
FTE is my crack
haha,, we did it ourselvees, me ,m my bro in law, a stihl. the 250, his dodge......
Old 06-08-2006, 12:04 AM
Bdox's Avatar
Bdox
Bdox is offline
Are there any wood turners in your neighborhood? They like spalted maple.
Old 06-08-2006, 08:30 AM
GLR's Avatar
GLR
GLR is offline
If you are into carving, you could carve a statue out of it. Looks like still a bit of cutting to do. If you are doing this yourself, cut it as close to the ground as possible, even digging out some dirt, then you can chainsaw out the middle as close as you can to the outer edges, then use an axe to finish up. Or make it into a redneck picnic table, which I am tempted to do to one of my stumps.
Old 06-08-2006, 10:16 PM
jake00's Avatar
jake00
jake00 is offline
FTE is my crack
I'm trying to find a place that will rent a stumpgrinder attachment for a skidsteer, but the chAinsaw and axe idea might work too
Old 06-08-2006, 11:34 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Why not dig around it, cut the roots a few feet underground and pull the rest over? I did that with a 30" diameter at the ground cedar tree in my back yard. Used a come-along. Slow, painful, but effective. No stump left.
Old 06-09-2006, 05:50 AM
Beast12's Avatar
Beast12
Beast12 is offline
You will not believe the amount of root that is below the ground. It will take a LONG time to "dig and cut" it out. I am guessing that it would take you at least 6-8 HARD LONG hours to get it out. Then you have this big chunk of dirty wood. Also, the chainsaw will be so dirty and messed up that you will end up having to replace the chain ($30 or so) and possibly the bar ($50 or so).
And make sure you get a GOOD say (see STIHL). One of those Sears specials is not going to cut it (pun intended). It will be sooooo frustrating that it is not even funny. Although if you video tape it and send it to me I will probably laugh my head off!
At least get 1 or 2 quotes from tree companies just to see how much it will cost. Most will give you an estimate for free.
-Matt
Old 06-09-2006, 09:13 AM
LilDuke's Avatar
LilDuke
LilDuke is offline
Originally Posted by Torque1st
...they are a PITA with all of the helicopters and leaves. I have 5 silver maples in the yard.
I have 2 acres with +/- 100 silver maples. From 6" to 3' trunks. I definately aggree with you on the seeds. However, I love having them. I live right outside of town, but you wouldn't know I'm here because of them. Great shade durring the summer. Between that and 2 creeks bordering my property, it's like living in the middle of nowhere, in the middle of nyc.
Old 06-09-2006, 12:35 PM
i1dery's Avatar
i1dery
i1dery is offline
Well try digging a hole under it as far as you can towards the center and stuuf two
sticks of dynomite and blow it outta the ground, it works well with fir trees in the
NORTHWEST
Quick Reply: Stump removal and what kinda tree is this?
