Another Engine I.D. Question
Hello! I recenty purchased a 1956 ****** that one the previous owners had installed a V8 into The engine is an old y-block (it has the 2 bolt valve covers). I would like to rebuild the engine, but I do not know what it is! I have been reviewing the threads here and some of the y-block sites to identify the engine. The only block ID I can find is B7ME6015A, which I would understand to be a 1957 Mercury. can anyone tell me about this, and what the cid is?
Also, it seems to have some kind of external oil pump that sits behind the pan(with an external tube that runs from the pump to the pan) . Does this sound right to anybody?
Thanks in advance!
Thanks in advance!
I cannot answer your question, but this page may help. It has all the Y-block "block" numbers. There are also the head casting numbers and other good information on it.
http://www.ford-y-block.com/Block%20identification.htm
I am probably reading it incorrectly, but it looks to be a 312 (62 and later replacement). Can that be correct? No clue. You better look. LOL
Pustman, welcome to the site and the world of Y-blocks? And what an intro into the Y's! Your motor does sound like a very rare one if it all checks out. A very late model 312 with C2AE main webs (extra strength). Dont let that get away.
Your combination is unusual too. Just think you may be the owner of a one of a kind match.
Yes that is the oil pump.
With your unusual block, it isnt clear what heads would have originally been on top. Maybe 113's but that is just a guess. Let us know what casting numbers you find the heads to be.
Many Y's have had their heads replaced by sets other than the original over the years.
Parts are readily available for everything you may need to replace. New oil pumps are a better idea than rebuilding the old one.
Although your block sounds to be rare, all the regular Y-block parts should fit fine.
http://www.ford-y-block.com/index.html
Do not be afraid to call him he doesn't read his e mail as often as you would think. He also is a really nice guy to talk to. lots of info on his site. He will also build a motor for you, knows y blocks inside and out... Gerry
Y-block
10-08-2013 06:36 PM
wagonwrench
01-06-2009 04:59 PM
BlueOvalRage
13
03-27-2002 09:46 PM
darkman
03-29-2001 09:47 AM
