Fuel gauge pegged? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Fuel gauge pegged?
Old 06-06-2006, 03:11 PM
Haymanwolf Haymanwolf is offline
Haymanwolf is starting off with a positive reputation.
Fuel gauge pegged?
Has anyone had their fuel gauge stay pegged full? and what was the fix?
Old 06-06-2006, 06:00 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts!
See you on the boards. .
Old 06-06-2006, 06:50 PM
Hellrazor1 Hellrazor1 is offline
Hellrazor1 is new and has a neutral reputation at this point.
No but mine was stuck at 1/4 after i filled the tank and every day it would jump 1/4 until it was reading right again. Weird..
Was on my '05 at F250 at work.
Old 06-06-2006, 07:01 PM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
Usually it is the float and or sending unit in the tank. Over time the float sometimes absorbs fuel and doesn't work as well, usually indicating less than what is there. Or the sender gets corroded or sticky and reads higher or lower than it should.
Only fix that I know of is to replace the unit which means dropping the tank etc. Depending on how many miles you have, if you drop the tank, you might want to consider changing the fuel pump too since it is in the tank and requires the same work. Manytimes the float/sender/pump is all part of one unit.
Alternatively I had one car where the gauge itself was faulty and had to be replaced.
Once in a great while it is a bad wire connection.
Good Luck,
Jim Henderson
Old 06-06-2006, 07:04 PM
desrcr desrcr is offline
desrcr is starting off with a positive reputation.
I ownand have owned many Fords, all the fuel gauges read funny (except my 99 Ranger) Some read full until half empty,others would read empty when half full. It seems to be a pretty common.
I rented a Thunderbird with a bad fuel gauge,traded for another with similar problem.
Old 06-06-2006, 08:59 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
dang i wish my fuel gauge would stay at full....
Old 06-07-2006, 08:58 AM
CmprSpecial's Avatar
CmprSpecial CmprSpecial is offline
CmprSpecial is gaining momentum as a positive member of FTE.
If you have one of the new SD's with a digital odometer you can get a get a reading of the what the fuel sending unit is sending to the gauge.
Start with engine off and press the trip reset button. Turn the key to the run position (or start it), but don't let go of the trip odometer button. After a few seconds, the odometer will read "TEST". From there you can toggle through the various readings. There are 2 for fuel level. One is an instant reading, the other is for an average (smooths out fluctuations).
Here is a link to another thread that identifies some of the other readings http://www.ford-trucks.com/forums/sh...d.php?t=458698
I am no expert, but if the reading is moving down as you drive and the gauge isn't, then a bad gauge would be the likely cause. If the reading is pegged, a sending unit or wiring issue would be where I would focus the diagnosis.
Old 06-07-2006, 09:02 AM
2002 F350V10 2002 F350V10 is offline
2002 F350V10 is gaining momentum as a positive member of FTE.
On older vehicles, if the fuel gauge wire is disconnected , gauge is decked 1 way, totally grounded out, gauge is decked the other way.
Old 11-05-2006, 04:44 PM
dallasbaker dallasbaker is offline
dallasbaker is starting off with a positive reputation.
05' 250 Fuel Gauge - Same Problem
I have had the same problem. 05' SD V8 2wd. I bought this truck a few weeks ago and the gauge was stuck on empty. I lowered the tank to check the wiring connections. After I bolted the tank back in, the gauge is now stuck on full!! Ha! This leads me to belive there is a connection problem somwhere near the tank. I haven't had time to check further, but I plan to put a meter on it next week. I have checked the readout on the dash and it matches.
I agree that this is usually a float problem, but it should not be in a truck that is less than a year old.
If anyone has the schematics for the sending unit or the nominal measurement, I would appreciate them.
Old 01-16-2007, 11:35 AM
Fuel Gauge Stuck - PROBLEM SOLVED!!!
Well I broke down and solved my fuel sending problem.
I have an 05 2wd F250 Gas.
The truck was involved in a frontal collision, which may have caused it. The float assembly had actually come off it's bracket and was laying in the bottom of the fuel tank. It was very simple to drain the fuel out and slide it back into place, making sure the tab was bent back over to avoid another occurence.
All of this was made easier by taking the bed of the truck off. You can lower the tank as well, I just found it easier to take the bed off.
Note: The 2 lines going into the tank have connectors that require you to push in on the tabs. It looks like you pull out on them. One is green on the sending line. Not sure what the other is. To get the unit out, just use a screwdriver and hammer to knock the retainer loose.
Old 01-16-2007, 01:02 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
I know on certain years of the SD, there was a known issue - if you purposely overfill the tank as far as you can get it, the float will stick at FULL.
Bad thing? You gotta remove the tank to fix it.
I'd still check the wiring and other associated things, especially that check to see what the float is really putting out.
Old 01-16-2007, 04:18 PM
point
Good point. I did check the wiring and tested the cluster first. I would recomend this before having to dive into the tank.
Fuel gauge emty stop peg Gicknordon 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 10-30-2016 09:22 PM
Dash gauges pegging? iwlbcnu 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-13-2012 09:38 AM
Aux Tank Gauge pegged and no dash lights! mountainsportsman 1973 - 1979 F-100 & Larger F-Series Trucks 2 11-18-2011 01:21 AM
Fuel gauge staying pegged Saxon Electrical Systems/Wiring 7 06-10-2009 10:14 AM
fuel gauge pegged roscoe 1978 - 1996 Big Bronco 6 04-21-2001 02:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
