1998 Ford Explorer High Beam Problem
Hello my 1998 Explorer's high beams are inop. Both low beams turn on ok. When the momentary switch is made for passing, the low beams stay on. When the switch is put into High Beams directly, the lamps turn off completely. The blue high beam indicator appears when I select high beams in either mode. Need help to pass state inspection. THanks
The multifuction light switch (wiper and lights combo) is most likely bad. I had the same problem (1998 xlt) basically where my high beams would come on sometimes but not at times. It's a common problem and the same multifunction switch was recalled by Ford for the 1999-2001 x's because of similiar type problems. Too bad they didn't recall the 1998's. I replaced mine and brought it at Autozone. Good luck.
Mickey
Mickey
(EDIT: the information below also is if you do not have the lights out module in the truck. Those are notorious for going bad as well but I do not have information on that. It also assumes you do not have the autolamps feature.)
If the blue light is coming on in the dash I am not sure that the switch is bad... I would suspect a bad relay or blown fuse. Looking at a preliminary copy of a 1997 EVTM for a Mountaineer (should be similar, but may not be the same) it appears that there are two contacts in the switch... one for the flash to pass and the other for the high beams in normal operation. This seems to indicate that in these cases both are working if they are illuminating the dash light.
In these trucks the high beam filaments of the bulbs are fed by separate power than the low beam filaments. Since you said that your low beams are working the main fuse in the power distribution box is fine. I would start by checking fuse 33 (15A) on the interior fuse panel and see if it is OK. If not you may want to replace it and see if it goes again... if it does you will need to track down the wiring.
If you decide that it is the multifunction switch that is bad (mine went bad as well, it was my wipers and turn signals that had issues) the replacement for that is easy to do as well.
Good luck.
-John B
Good luck.
-John B
Yeah, like John sez the only thing between fuse 33 & the high beams is a splice. One wire from the splice connects to the high beam indicator on the dash and the others connect to the headlights & DRL module if you have daytime running lights.
Looks like the problem is a bad connection in that splice.
Seeing that the EVTM seems to indicate that the DRL module is reponsible for lighting the lamp in the cluster does this mean that they all have a DRL module in them? Even if you do not have DRLs? Or is there a bypass installed instead?
OOPS, took another look at the wiring diagrams, & heres the correct info.
If not equipped with daytime running lights the splice between fuse 33 & the headlights is wired to the headlights & to the high beam indicator on the dash.
On trucks with DRL's the splice is wired to the high beams AND to the DRL module & the DRL module is wired to the high beam indicator on the dash.
Either way, it looks like a problem in the splice or as John sez, both high beam filaments might be burned out.
DaMonsterMonster
11-29-2015 08:23 PM
bronkntrukholik
01-21-2010 07:00 PM
