Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-05-2006, 03:40 PM
homer4111 is starting off with a positive reputation.
lifter question for early 352 using 901 cam
i took mt 1959 352 and had it bored .050 and using 390 crank n rods. bought crane 901 cam had front of block tapped for cam retention plate. now the question the oroginal lifters are 2.00 in tall the lifters that came with cam are 1.840 do i need different lifters to make this cam work or do i need longer pushrods thanks for any help keith
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-05-2006, 03:54 PM
just a update to my question. the pushrod does sit at the same height installed the difference is the outer shell of the old lifter is taller. is this ok?
  #3 (permalink)
Old 06-05-2006, 04:47 PM
RapidRuss's Avatar
RapidRuss is starting off with a positive reputation.
Sounds too me like you need .140" longer pushrods to bring the geomitry all back to zero.... JMO..
Russ
__________________
Blue Saphire 70 F250 390/C6 Limited Slip 3.73
Hedman Full length
Holley 750
BFGs With Turbine Wheel
With Some Damn BBF Morphing into something? Might be done by 2009? But will be wicked!!
  #4 (permalink)
Old 06-05-2006, 06:42 PM
the push rod still sits at the same installed height at the rocker arms i was wondering about the height of the shell that sits in the lifter bore?
  #5 (permalink)
Old 06-06-2006, 08:56 AM
Putt's Avatar
Putt is starting off with a positive reputation.
Is the block an original solid lifter engine?? If the lifters you removed were solids, it cannot use a hydraulic lifter cam. The early blocks can be solid lifter only. Check the lifters you removed, if you still have them. Oh, are the rockers adjustable??
__________________
Putt
1966 F100 4X2 428 4 and 3 sp. 2.75:1 rear
1989 F250 Super cab 351 4X4
1965 Mustang coupe w/289 2bl.
  #6 (permalink)
Old 06-06-2006, 10:21 AM
hiball3985 is starting off with a positive reputation.
I think 58 blocks were solids, in 59 they went to hydraulics but still had adjustables if I remember right
__________________
JIM
1960 F100 Panel
223 3 spd overdrive
1966 F250
390 4 spd
  #7 (permalink)
Old 06-06-2006, 03:12 PM
the old lifters were hydraulic just shorter in body height
  #8 (permalink)
Old 06-07-2006, 06:31 AM
the rocker arm geometry appears to be correct
  #9 (permalink)
Old 06-07-2006, 08:38 AM
does your 352 have adjustable or non adjustables rockers?
__________________
JIM
1960 F100 Panel
223 3 spd overdrive
1966 F250
390 4 spd
  #10 (permalink)
Old 06-07-2006, 10:01 AM
Putt's Avatar
If the pushrod seat in the lifters is the same height from the base, then it is just a different style I would think. As long as the pushrod geometry is correct there should be no problems, just make sure the lifter is not uncovering something in the bores that was covered by the old, taller lifters.
hiball, you are correct in the years you gave. There were more solid only blocks after that, but not many!!
__________________
Putt
  #11 (permalink)
Old 06-08-2006, 06:13 AM
i think they will work as the oil port in the new lifter is in same place as old when both lifters are sitting on their base. they just looked a lil strange when i dropped them into the lifter bores thanks guys
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
