Dahl owners, change your filters - Ford Truck Enthusiasts Forums
Old 06-04-2006, 11:53 PM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is offline
Fat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud of
Just a reminder to change your filters if you aren't running a vacuum gauge. My Dahl 100 creates about a 2 inch of mercury vacuum at idle with a clean filter. I looked at it the other day because I could hear air cavitating in the pump and it was pulling something like 22. Yikes. Changed the filter, eliminated the cavitation sound (might have been drawing air at the fittings/clamps), and now I am back to 2.
Don't forget to burp it either!
Old 07-16-2013, 03:58 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
"Lonely old post" reply guy here:
Mine gets changed about once a year, just before I go "east".
I'm using a two-micron filter in there, and the stock fuel bowl's filter stays spotless!
I now wonder if a gauge wouldn't be a good thing for me to add.
Pop
Old 07-16-2013, 05:40 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
If pre-pump filtration was stock on these rigs, the biggest advice on the forum would be the after-pump fuel filter... or "Post-Pump Purifier".
In answer to your question, the vacuum gauge pre-filter and fuel pressure gauge post-filter would give interesting information... but it's not idle where the issue is.
Mounting of a Dahl 100 on an Excursion MV7 Excursion - King of SUVs 10 08-13-2015 11:41 AM
Hutch Mod Question MV7 1999 - 2003 7.3L Power Stroke Diesel 5 08-11-2015 10:35 PM
motor missing at WOT fyrehose 1999 - 2003 7.3L Power Stroke Diesel 1 11-06-2014 08:18 PM
fuel filter change gone bad turbojunkie 6.7L Power Stroke Diesel 3 08-01-2011 08:09 PM
By-Pass Oil Filter Recommendation firemediceric 1999 - 2003 7.3L Power Stroke Diesel 27 03-24-2007 03:10 AM
Tags
73, change, dahl, filter, ford, gauges, power, powerstroke, stroke, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
