Intech 4.6 Questions
ok fellas i have a little question. ok i have a brand new Continental Intech DOHC all aluminum 4.6 here. the problem with the motor is its from a Continental, FWD, so the block will not work for it to go in my 1958, i know this. but would it work or be worth it to get a new iron 4.6 block from the Ford Racing Catalog for about 300 dollars and putting everything from the Intech into and on it. or is this a bad idea for some reason. and also in the catalog they only list a SOHC block, no DOHC block is this just because theyre identical blocks or some other reason. thanx in advance.
ReluctantMechanic
04-26-2016 09:27 PM
