Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-03-2006, 09:49 PM
billb7984 billb7984 is offline
Garage is empty, add now
billb7984 is starting off with a positive reputation.
?? carb running way to rich??
Hey guys
I have a 47 ford truck with the flathead v-8, and it has a chandler groves carb on it,well it is running way to rich,the plugs look real black,and it is also very hard to start,I had the carb rebuilt about two years ago,and it has always been hard to start,any ideas????
thanks Bill
__________________
billb
  #2 (permalink)
Old 06-04-2006, 04:20 AM
Steve_B's Avatar
Steve_B Steve_B is offline
Steve_B is gaining momentum as a positive member of FTE.
Are you running a electric fuel pump ?
You only need 2-4 psi, electric pumps put out more than this forcing fuel past the float valve
I had to fit a pressure regulator in line
Steve
  #3 (permalink)
Old 06-04-2006, 05:37 PM
no it isnt a electric fuel pump,thanks for asking.
__________________
billb
  #4 (permalink)
Old 06-04-2006, 06:10 PM
kotzy kotzy is offline
kotzy is starting off with a positive reputation.
First thing you would need to check is the float level. Since
you had a hard time starting it before, the rebuilder may have it
set to high.
Tags
47, adjust, carb, flathead, ford, rich, running, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
